LT1 to LS1 brake upgrade
How hard is it to upgrade a LT1 brake system to the same system on an LS1, (does it just take calipers, or do I need to do the whaole system. THANKS in Advance.
i did it on my 96. it's easy. you need a 98 and up knuckle,cailiper, cailiper bracket, brake line to caliper bolt and rotor. also if you want a 98 and up brake like. it's easier if you get the 98 and up brake line unless your on a budget. the hub's are the same. then all you do is swap the knockles. and all the 98 stuff bolt's to the 98 knockle. i can't find the link with pictures a step by step guide. honestly your better off saving up for the c5 upgrade.
