Rear passenger side suspension lower than right side?
My rear passenger side wheel has about 1 inch less clearance to the
wheel well opening than the drivers' side rear. The springs and shocks are the same. Swapping the springs from pass to driv. side etc. makes no difference.
What else determines this spacing? It is a 2000SS and has the stock
torque arm and a track bar in the back in addition to a rear stabilizer bar.
Thanks,
Gert
Thanks,
Gert
If it makes you feel any better, my 00' WS-6 does the same thing. From previous posts, it's a pretty common thing.
I wouldn't worry about it.
I've yet to hear a good explanation for it.
if this makes you feel any better
https://ls1tech.com/forums/suspension-brakes/419503-found-solution-saggin-rear.html
