Battery Relocation with t-tops?
Here's a link to a webpage outlining the specs of an Optima Redtop battery:
http://www.supertrux.com/Product%20S...0Batteries.htm
As you can see, the heaviest version they make is 17.6 pounds and has 1050 cranking amps. If you went with this setup, you're not going to add any weight to the car in comparison to what the stock battery weighs, you'll just be putting it where the car can benefit from it the most.
This is in my 98 TA Dale
Battery tray 10$ Also NAPA
This is the terminal block I made (I work in machine shop)
__________________
With a block like this you can switch back to stock.
Is it harder to start the car as well?
Car starts just like before
I used #1 cable,if you use smaller cable it mite start harder .
I also added 200A fuse near battery--see pic. in post 26
Dale
