Battery Relocation with t-tops?
Old Dec 21, 2005 | 10:42 AM
nomorews6's Avatar
Default Battery Relocation with t-tops?
Has anyone done this? I was thinking about mounting the battery where the ttop shade is right behind the back seats. In the trunk it wouldn't work because the ttops would be there. Any ideas?
Old Dec 21, 2005 | 11:29 AM
Predator's Avatar
Have you considered a lighter battery instead? A lot of the racers are going with a Hawker Odyssey PC680, weighing about 13 lbs.
Old Dec 21, 2005 | 12:47 PM
nomorews6's Avatar
very cool - how much weight savings is that? any problems with it at all?
Old Dec 21, 2005 | 01:17 PM
Predator's Avatar
I don't have one yet, but I'm getting one. I think the stock battery weighs about 35-40 lbs, so that's a significant amount of weight off the nose of the car. Most reports are that it works fine, even when the temps drop.
http://www.gotbatteries.com/items.as...SL105/37L105S5
Someone here posted this picture and I saved it. I hope it's okay to repost it.
Old Dec 21, 2005 | 01:18 PM
nomorews6's Avatar
thanks!
Old Dec 21, 2005 | 01:30 PM
thesoundandthefury's Avatar
What about mounting it in that little cubby hole on the driver's side of the trunk? I'm assuming the reason you're not mounting it the conventional way is because you want to keep your spare tire? If you mounted it in the cubby hole you could keep your spare AND still have the space to store your T-tops.
Just an idea.
Old Dec 21, 2005 | 01:32 PM
nomorews6's Avatar
oh! people do it in the spare tire well? I don't have a spare tire anyway so that would be ideal. How tough is that?
Old Dec 21, 2005 | 01:54 PM
Korben's Avatar
It's easy. They make relocation kits specifically to go there.
Old Dec 21, 2005 | 02:06 PM
nomorews6's Avatar
awesome! has anyone seen a 1/4 mile time drop just from doing this?
Old Dec 21, 2005 | 02:14 PM
DONAIMIAN's Avatar
About the 1/4 mile time drop, im not sure, but it wont hurt it being weight off the nose.
Old Dec 21, 2005 | 02:16 PM
http://www.pfyv.com/product.php?productid=1055
Easy as pie.
Old Dec 21, 2005 | 02:26 PM
nomorews6's Avatar
so next question - since the other battery is like 13 lbs or something, is it worth it to put the 13 lbs on the back?
Old Dec 21, 2005 | 02:33 PM
Predator's Avatar
When you relocate a regular sized battery to the rear, you're actually adding more weight to the car than when you started.
It's not recommended having long cables on the Hawker batteries, so no, you'd have to keep it in the front.
Old Dec 21, 2005 | 02:35 PM
blue01ta's Avatar
It's always good to take weight off the nose and put it over the axle. Every little bit helps.
Old Dec 21, 2005 | 02:36 PM
nomorews6's Avatar
so what is better? hawker up front or stocker in back?
Old Dec 21, 2005 | 02:54 PM
Predator's Avatar
That's a tough call. I'd always rather take weight off my car if I can, but Car Craft had an article claiming that you could lower your ET by adding weight to the rear. I guess it depends how you use your car. Also, the 27 lbs. or so of weight you'd save going with the Hawker is like gaining about 3 hp. Tough call though.
Old Dec 21, 2005 | 03:00 PM
nomorews6's Avatar
I'd imagine the kit itself would probably be 10lbs also or something. So going from 50lbs to 13lbs. I'd say hawker would be best.
Ace$nyper's Avatar
When I got my car it had and still does have a sub where it would be relocated to I think with how much they weigh and the hassles involed compared to a light one isn't worth relocating for a daily.
I think upgrading to the light weight one is a better investment.
Old Dec 21, 2005 | 03:05 PM
Predator's Avatar
That's what I'm doing, FWIW.
Old Dec 21, 2005 | 03:30 PM
DONAIMIAN's Avatar
I would rather put it out back and run an optima battery, reasoning is the optima is a more reliable choice.
