Line Locks
Old Dec 26, 2005 | 10:50 PM
hllywd's Avatar
Default Line Locks
Anybody have any preference between SLP line locks or Hurst line locks?
Thanks
Old Dec 27, 2005 | 09:21 AM
SJM Manufacturing Inc's Avatar
You may want to consider our kits. They retain features and benefits where an SLP kit fails.
SLP kits do not have the advanced protective circuitry nor feedback circuitry our kits retain. There's are not rebuildable, all our kits are.
Between a hurst style and biondo style, both are quality units. For the best bang for the buck, the B-001 kits are our best seller @~125.00 Differences in cost between our hurst style and others are solely due to the solenoid itself.
All kits retain a master switch AND control switch and include a remote LED indicator including all electrical needs. All kits come PRE-ASSEMBLED no Teflon tape necessary! We even include a grommet for the firewall!
We've got the largest selection of LL and ABS kits on the market for your car. All kits are always in stock and ship within 24 business hours guaranteed.
You can view all kits listed in the "Braking" section of our website.
Old Dec 27, 2005 | 09:32 AM
01 Red WS6's Avatar
I would get a kit from SJM, they have really nice stuff. If I had it to do over again I would get one from them
Old Dec 27, 2005 | 08:42 PM
Blown Ta's Avatar
i got the sjm kit, no problems yet.
Old Dec 28, 2005 | 04:05 AM
mattr228's Avatar
have the SLP line lock , have had no problems with it and has been heavily used
Old Dec 28, 2005 | 07:24 PM
shaZZam's Avatar
I just finished installing the SLP kit. Boy what a complete PITA The instructions that are included with the kit are a joke, and the photographs are almost useless (except to show you the general area in which to work). Maybe I'm just old, stupid and blind, but in hindsight, sounds like the SJM kit has everything that the SLP kit doesn't. This (SLP) is a very basic kit and is probably the most expensive.
Old Dec 28, 2005 | 09:38 PM
The SLP kit is what I would consider a bare-bones setup. Before SLP decided to carry their line lock kits, their sales associates used to recommend our kits through their vendors (at one time (I’m talking way back in ~1995-6),, our kits were only available through vendors not directly with us). Since then, .they came out with their so called “exclusive” kits.
I would highly advise if you install an SLP kit, add at least a master control switch or something that lets you the circuit is live AND so it can be disabled. SLP kits use an on/off NON-momentary switch to control their circuit; no manufacture uses this type of control without additional safety protection. I do not believe this is track legal, nor is it safe.
…safety considerations…If you leave it switched on you may not know it is armed...cleaning your car, switching it on (leaving it armed unknowingly), you can burn the solenoid out. Your curious buddy while driving decides to switch the switch without your knowledge...stepping on the brakes without knowing it is armed leads to a very hazardous condition obviously. I think I read someone recently ran into the store, came back out and went to move the car, and it wouldn’t move since the line lock was armed accidentally. Do not run solenoids for more then 60 seconds. This is the general rule for all LL solenoids.
OUR KITS: I feel our directions are quite complete. In addition to words (for those whom do not like to read) we do have install pictures, as well as a full wiring schematic diagram included. We offer full customer support for the products we manufacture and design (and warranty them too).
We offer for the LS1 F-bodies (Biondo style B-001) configuration in both front mount kits (how SLP copied our design) or the top mount kit which is much easier to install. The top mount kit is much easier to install due to the physical mounting location of the solenoid in reference to OEM components which can get in the way when you try to drill and mount the solenoid.
As mentioned our kits are complete with all the bells and whistles included with pre-installed fittings (no Teflon tape necessary)…master arm switch with remote LED indicator and momentary control switch…down to the rubber grommet for running the wire through the firewall….always in stock guaranteed shipping within 24 business hours
Steve
President
SJM Manufacturing Inc.
www.sjmmanufacturing.com
Old Dec 28, 2005 | 09:56 PM
Bluewire's Avatar
Do you make a line lock kit for the 97 to 04 Corvette yet?
Old Dec 28, 2005 | 10:05 PM
We have the components to do so. We did have one donor car that we were willing to install the kit so we had a prototype for mockup...the customer ended up canceling and decided against modifying the car from stock.
IF we had a donor, we would be more then happy to work something up for you guys. There was a company that made up a kit (can't think of whom it is but did see something at one point)...it seemed quite expensive in comparison to any-other kit out there (probably due to they were the only ones making it). For some reason, corvette components are typically more expensive...
Old Dec 28, 2005 | 10:21 PM
Bluewire's Avatar
The only kit I know of was by Cartek and it was hit or miss if it worked (from what I searched). I was going to just buy a line lock and make up some lines, I just don't know what kind of fittings I need. I don't want to take it apart just to get fitting sizes and then have to order them and do it again.
Your kit sounds real nice, if you had one and didn't tack on Corvette tax I'm sure you could sell more than a few.
Old Dec 28, 2005 | 10:39 PM
lol, we do not induce corvette tax. The price of the kit would be very similar to our other kits. The main thing different is the line sizing...that is about it offhand.
If you made up the kit, you'd need a few specialized tools as some of the bends coming off the master cyl are very tight...a standard tube bender won't cut it.
We do not have any late model corvettes to work from...only old school vettes.
Old Dec 29, 2005 | 02:23 AM
Pimpium57's Avatar
Props to Steve@SJM for a killer system! I've had one for the entire '05 season w/o problems.
Old Dec 29, 2005 | 06:54 PM
mattr228's Avatar
the SLP kit only took about an hour to install for me, wiring , installation and bleeding the brakes
i also have a master switch with a 'armed' light letting me know if its on .... which ran be about $2, if that, more in parts to do so
steve10 - what exactly is the point of having two switches to control the LL ? I can see if the momentary switch fails you can control it by the master switch, but then that would be a problem of the switch failing -or- faulty wiring, not the LL solenoid, or is there a safety feature in the solenoid that allows pressure to be bled off if it fails?
after as many uses i have put my LL through, maybe it wouldnt hurt to replace the solenoid
i do have a problem after i use my LL recently (not sure if its a LL created problem) , at the top end of the track, when i apply the brakes it will give a stiff feel to the brake pedal , and i have to pump the brakes (about two times) for it to eventually grab & slow the car down .......... but that is with the LL switch disabled and launching w/ a foot brake, but the LL is used during the burnout
Old Dec 29, 2005 | 07:37 PM
The switch is important as you stated...if the the control switch fails and is sticks closed, you can still shut it off (cruise control has two switches redundant features as well. First one turns on the CC, then the other one is your activation switch).
The other reason why CC uses two switches is so that you don't accidentally turn on the CC without knowledge. The main master Cruise Control switch completely deactivates the ENTIRE circuit. ...This the exact same function of our LL kits master control switches.
When you’re not going to use the LL, keeping the master arm switch of ensures you (or anyone else) does not switch the circuit on. You or someone else can depress the control button all day long and it won’t activate.
When you switch the master switch, the remote LED lamp illuminates letting you know the circuit is live and the control button can be used at any time (once again, just like how your cruise control momentary button works).
We choose instead of using a single master switch with LED to use a separate master switch with remote LED. The single switches are large and cannot be hidden easily. If you do find a good hiding place for it, then you can’t see the LED. Our switches are small, can be mounted in a variety of locations and the LED lamp can be easily mounted anywhere on the dash which looks stock and is very visible when illuminated.
If you still kept the original switch (non-momentary control switches I do not believe are track legal from my understanding), then adding the extra switch to completely deactivate the circuit is a very good move.
I'd suggest for the folks considering a line lock, they all will function the same and work all alike, it is the features and benefits that makes kits different. Ours I believe are the best, safest and most complete on the market and have been proven since ~1995!
Instead of purchasing a component, then spending additional funds and the knowledge necessary to wire-in additional components (I'd imagine you needed more then 2 dollars worth of parts but if you got it for that little good job!)...you'll need connectors, switch with LED or separate high lumens LED, additional wire and a few other misc pieces. Purchase a complete kit that retains the features that you require.
