VIBRATION ON HIGHWAY ?...come inside
Old 03-21-2006, 08:35 AM
  #181
JB00SS's Avatar
I have pacesetter LT with ORY, factory I-pipe with SLP dual/dual. I still have factory muffler.
I just ordered prothane mounts from summit. this weekend the bitch will run and if she vibrates and "wom wom wom's" then i will drive her off a cliff and not look back
Old 03-21-2006, 08:49 AM
  #182
ninobrn99's Avatar
you do plan to jump out of it first right? pacesetters, TSP catted y and stock Ipipe and muffler. my ipipe is resting on my tunnel brace, so once that gets fixed, then ill see if that does anything to help out.
Old 03-21-2006, 08:53 AM
  #183
JB00SS's Avatar
ninobrn99, what u-joints do you have with that PST driveshaft. Mark wiht PST told me to keep my stock type said going any bigger wouldnt do much since i am still on the stock 10 bolt???
Old 03-21-2006, 08:55 AM
  #184
ninobrn99's Avatar
i have their 1350 joint. Ive got a 9" so i needed a bigger ujoint and didnt wanna run the stock DS. I also spoke with Mark. Cool guy!
Old 03-21-2006, 09:19 AM
  #185
JB00SS's Avatar
cool he told me the stock size u-joints will be fine since i have a 10-bolt still and there would be no use in changing to bigger.
Old 03-21-2006, 09:24 AM
  #186
ninobrn99's Avatar
nope, all you'd need is a napa 447 1310-1350 conversion when you do get a new rearend.
Old 03-21-2006, 09:45 AM
  #187
1QUIKWS6's Avatar
I totally agree that even though we all have vibration problems - it may be due to several contributing factors - and different ones for each of us.
In my case I am not using poly motor mounts/tranny mount - nor do I want to. The main reason people are using from what I can tell is to stiffen up the motor/tranny combo in order to alleviate ancillary components such as the exhaust from hitting the underneath of the car. This may work, but is nothing more than a bandaid for the problem - which, in fact, INCREASES the amount of vibration the driver feels from the driveline due to the stiffness of the mounts.
I have checked my entire exhaust system and it is not even close to hitting anywhere - so that is not a factor in my vibration.
The vibration in my case seemed to start with the install of the Spohn T/A - I previously had a Random Tech T/A that mounted in factory location of tranny tailshaft with no vibration. Again, I am not blaming it on the T/A itself - but feel that my PA is highly suspect as to how it was set.
The vibration is present at/around the same 70mph speed no matter which DS I use - and (2) of them were expensive, supposedly highly accurately balanced versions. The vibration in my case DOES get worse the higher the mph goes above 70. I also realize that this is a RPM related vibration not mph - but everyone's rpm will be different due to rear gearing.
The vibration is NOT located in my engine or tranny - I can put the car in neutral and rev it to 7K and there is absolutely NO vibration. In my case I can also rule out the rear as it has a fresh rebuild and that rebuild was done before the addition of the Spohn T/A and the start of the vibration. My vibration definitely originates somewhere between the tranny and rear.
Old 03-21-2006, 11:23 AM
  #188
StripedZebra's Avatar
I just swapped out my entire exhaust for pacesetter LTs and ORY. Still have the vibration. Also, im on the stock TA.
For those of you havnt seen it, here is my video of my vibration http://video.google.com/videoplay?do...11462900636130
Old 03-21-2006, 11:28 AM
  #189
JB00SS's Avatar
is your wom wom wom noise still there plus the vibration?
Old 03-21-2006, 11:32 AM
  #190
1QUIKWS6's Avatar
I assume your car is lowered? Because if it is, you have changed the suspension geometry regardless of what T/A you have.
That vid of your vibration is worse than my vibration - and I thought mine was bad
Old 03-21-2006, 05:23 PM
  #191
Mike2000Z28's Avatar
update: I took my car down to a local shop that deals with high end cars, some ferraris,porsches, and bmws etc... they are the best in the area. I just got a call that they have checked a few things and believe that they, after balancing the tires/rims, they believe they have the vibes solved but believe that I have an engine miss balance due to some vibes at 1700 rpm.
Old 03-21-2006, 05:59 PM
  #192
illy5603's Avatar
The thread that will never die! Here is my Vibe story. When I bought my 2001 SS last summer it had a really bad vibe. The fix for me was new Rims and Tires. Even ballanced rims can vibe if the tires have flat spots or other problems. I think mine were just not ballanced. My last Camaro (2000 SS) developed a Vibe after I lowered it.
Old 03-21-2006, 06:14 PM
  #193
1QUIKWS6's Avatar
Well, I never thought about flat-spotted tires. I was told that the new design radials don't really have that problem? But I can see that if they did, that might be a source for vibration in my case - maybe not all - but a contribution.
My car sets in the garage under cover from November to April every year - and it's setting on the tires most of the time (unless I'm working underneath).
Old 03-21-2006, 10:23 PM
  #194
I thought about that for some time, almost bought new tires and tires. I'll let everyone know whatz going on tomorrow night about the rims and tires, the shop I have the car at thinks they have the problem solved.
Old 03-21-2006, 11:34 PM
  #195
When i say my vibration, im talking about the wom wom wom. You saw the vid. The vibration is caused by whatever is wom wom womming.
Old 03-22-2006, 03:50 AM
  #196
ninobrn99's Avatar
damn, guess i better put my new hood on hold and get some ws6 rims or something ****! any my tires are new
Old 03-22-2006, 08:24 AM
  #197
JB00SS's Avatar
last night i put my ES TQ arm poly bushing on the factory arm. Put a new rear seal in the tail housing. i put my ES tranny mount back in also. I am waiting on my PST driveshaft to arrive. I am also waiting on my Prothane mounts which should arrive today from Summit. Then mounts i am re-thinking due to heads on the work bench and having to drop the headers anyway. I probably should do them then and save on the cuss words front wheels and tires i plan to have them switched and balanced by the weekend.
flat spots are something i am sure i have due to the car sitting so much. I try to drive it to work once a week but due to the mess i am in now the car has not moved in 2 1/2 weeks. I know the drivers front is cupped real good. the rears are BFG drag radials and i want to have them balanced again. i have owned them since June of last year.
i still have the UMI LCA's and relo brackets to put on but i am not a welder and am trying to get my buddy over to weld them just waiting on him to find time.
I hope all this helps but wont know anything till the weekend after the driveshaft arrives.
Old 03-22-2006, 09:09 AM
  #198
ninobrn99's Avatar
who all has an U/D pulley?
Old 03-22-2006, 09:27 AM
  #199
1QUIKWS6's Avatar
I have the ASP UD - but it had been installed for 2 years with no vibration problems prior to my recent vibration problems...
Old 03-22-2006, 09:29 AM
  #200
ninobrn99's Avatar
just trying to figure something out first i have the asp 25% again, i didnt notice vibrations either, but i have had a few issues that may be related to the pulley. mainly shaking under high loads. not too relevent to this, but more for me.
Quick Reply: VIBRATION ON HIGHWAY ?...come inside
