VIBRATION ON HIGHWAY ?...come inside
curious on this topic too.... i have an adj. TA and it still does it. it didn't vibrate when i had my aluminum d/s in but then it started after i had a custom steel one put in. so i dunno
Originally Posted by Marc '99T/A
And the noise would've gotten on your nerves so much before that point that you would've replaced them anyways.
My thoughts exactly... thats why I havent messed with the bearings yet. Any other time an axle bearing failed you definately knew it was bad.
I have this exact same problem. I check my tranny mount, which is fine. Its an Energy Susp. mount and i heard they can throw off drivehshaft angles, but i dunno. also replaced my stock steel driveshaft (97 car) with one from an 02 SS, but that didnt fix it either.
Im gonna check my motor mounts and see whats up with them. Also, im about to do headers so if it stops then ill know it was my exhaust. I also have a new torque arm bushing that im gonna put on. AND, when i can afford it im gonna try an adj torque arm caue im sure my pinion angles are off bein lowerd and all.
Ill keep this updated as iwould like you guys to do the same. This problem is really damn annoying.
As far as anybody having an ES poly trans mount, you could try to remove the plate, shave the bumps, then reinstall the trans mount without the plate. I did that and most of the vibration went away. I then had to switch to a torque arm that can yield a good pinion angle when the driveshaft is cranked by the engine. Some aftermarket fixed arms can work, however some drivers prefer an adjustible TA.
Lowering an F-body won't create many problems if you do it right and not attempt to "slam" your body. You can resolve most of the problems, however you must ensure that you will have good suspension and driveline geometry when doing so.
5.7lofun I'm at the point of removing the tranny mount and getting an adj torque arm, right now I have an Edlebrock non adjust in there now. I have been through the bearings, no noise, no looseness, nothing. I hope one of us would figure something out, its starting to **** my wallet off and my highway driving. I wish I could be more help to us.
I know the feeling, i was at the point of frustration where i was thinking of getting rid of the damn car....haha I absolutely cant stand driving on the highway cause ill have cheapo economy cars fly by me that probably have a smoother ride than my car.
In response to foxxton, my car was only lowered an 1 1/2" and i tried to do everything right (to best of my knowledge) by getting new LCA, relocation brakets, Adj PHR, and proper springs. I guess an adj TA is needed when lowering the car to correct pinion angle , cause it seems a lot of the people having this problem who have been through the run around are people with lowered cars not having an adj TA
Im just glad there are other people having my same problem! That way we can all try stuff and find out what it is. Ive thought about sellin the car too, its pretty embarassing when people think that you have a fast car and your on the free way with them vibrating like crazy.
I also get a little bit of steering wheel shimmey. The car has only 42,xxx miles, new tires (balanced), new rotors(that helped a little), and has never seen the track. My car is at stock ride height too...
I'm not selling the car, I would rather buy save up and buy a new rearend then sell it. I dunno kids the only thing I can think of is pulling the tranny checking the output shafts and then the adjustable torque arm. I don't see evidence of the output shaft on my driveshaft, but I believe I will need another set of ujoints. If I get a good tax return I'm almost thinkin of get Z06s so that I can totally eliminate the wheels then just balancing the tires. Very frustrating and I can almost guarantee that no one goes through the rippin like I do. My roommate has a 12.0 sec 5.0 that will not shut up. We can't figure out whats going on with my car after all the work that we have done.
#32
If your driveshaft ends up being a problem, then plan on replacing it with one that is properly balanced with the ability to handle the Hp/Tq that's being thrown at it.
EDIT: Not to forget, unless you're absolutely sure that your flywheel is balanced, you may need to have that checked as well.
Some may see me as being too broad with my diagnosis, however one part of the driveline can present problems that can and will affect other parts of it as well.
#35
no wheel bearings only require removing the cover and a clip out of the diff then the c clips, should be able to get the axles right out. The most exciting thing about checking out where the vibration is was replacing the old axles with the new ones, the abs rings sucks.
#36
Originally Posted by JB151
Like previously mentioned...be sure to check pinion angle it can cause horrible vibration.
#37
BMW ///M Nerd
Originally Posted by 5.7LoFuN
yeah, i have never heard of marking it (not saying your wrong) i even asked the guy at the driveshaft place who all they do is custom driveshafts and he said just slide it back in there. I would also like to know what problems could arise from not putting it in the same exact way...dosnt make sense to me how it would make a difference. ( once again not saying your wrong)
I really don't see how worn bearings could cause a wobble. I mean, you would have to have worn the bejesus out of them, I would think. And the noise would've gotten on your nerves so much before that point that you would've replaced them anyways. Just my 2 cents.
Checking tire balance, worn suspension components, driveshaft balance, etc. are all great places to start. They are also the easiest, sometimes you have to look a bit farther, and harder to solve the problem.
#38
Originally Posted by BAD *** TA WS6
Well, he's right. Always mark your splines, and align BOTH your u-joints together. If your driveshaft guy said just throw it back in there, I suggest finding a new "specialist."
#39
BMW ///M Nerd
well maybe he assumed i already had marked it when i took it out. I cant figure out the concept of why it would matter, but obviously it does. So what do i do now.....i already took it out and put it back in without marking it so is there even anything i can do about it now ? what problems will come from not having it in there properly ?
You shouldn't really have any problems to speak of. All that's going to occur is possibly vibration, and any bi-products of that vibration.
Just make sure the U-joints are installed the same way. Think of it like a compass, only the north/south would be the same, and like wise with east/west. Hopefully that paints a picture in your mind.
The idea is that the driveshaft is balanced, so you want you U-joints to be installed symmetrically to each other. This of course assures that the entire assembly is balanced.
Few quick questions,
You never checked pinion angle correct?
How low is your car, or better yet, what springs did you use?
Are you running LCA relocation brackets, what about LCAs themselves?
Rob
#40
My car is on sporlines. Never checked the angle and i dont know how...
I didnt mark my ds or anything either. It was doing this before i swapped out to the aluminum, and even before i lowered if i remember right.
I have a video of the vibration, but i think the file size is huge and i dont have anywhere to upload it (its a .mov).
