control arm help
Old Jan 17, 2006 | 06:26 AM
Dannyboyz28's Avatar
Default control arm help
I just installed a set of tubular lca's over the weekend and now it feels like the shocks are popping.... it never done this before i installed them.. i followed the instructions on installuniversity.com... any ideas??????
Old Jan 17, 2006 | 10:36 AM
Bueller.......Bueller..... can anyone start me in the right direction??????????
Old Jan 17, 2006 | 11:23 AM
vigil's Avatar
Feels or sounds like popping? I'd just double check you torqued them down tight enough that there isn't any slop.
Old Jan 17, 2006 | 11:40 AM
it sounds and feels like there popping ... its pretty loud
Old Jan 17, 2006 | 11:46 AM
ninobrn99's Avatar
did u torque them to 70 lb ft?? are they lubed? are the nuts and bolts installed correctly? meaning the head of the bolt is on the outside and the nut on the inside or however they were stock?
Old Jan 17, 2006 | 12:14 PM
yeah i definetly lubed them i just have to throw a torque wrench on there and double check the 70lbs... and i believe the bolts are in the right way
Old Jan 17, 2006 | 12:37 PM
ninobrn99's Avatar
you didnt over lube did ya?
Old Jan 17, 2006 | 01:33 PM
damn i could of how many pumps??? or do you just wait until it comes out the sides.. if i did over lube how do i fix
Old Jan 17, 2006 | 01:44 PM
ninobrn99's Avatar
if you over lubed, your gonna need to get new bushings if they mushroomed. you just need a pump and a 1/2 or so..maybe not even that much. try removing the zerk fitting and see if any oozes out. the bushings are just halves so you can just pull them out. I have spohn lcas and ordered new bushings for about $30 bucks i think it was...
Old Jan 17, 2006 | 01:53 PM
thanks alot for everyones help... where did you get the bushings????
Old Jan 17, 2006 | 01:55 PM
ninobrn99's Avatar
i ordered mine from Spohn.
Old Jan 18, 2006 | 01:47 AM
0rion's Avatar
After my subframe install my LCA's popped also. Just retorqued them and all was good. Make sure they're tight enough.
Old Jan 18, 2006 | 06:55 AM
so i took the zerk fittings off yesterday and bounced the back of my car, three inches of lube came out.. yeah i know but then i torqued the bolts down to 70lbs drove off and it was fixed.... until this morning doing the same thing ... the nuts prolly backed off, ill throw some locktite on the bolts this time.. thanks for all the help
Old Jan 26, 2006 | 07:25 AM
Alright guys this is really frustrating. i torqued the bolts down to 75lbs and threw locktite on this s.o.b and the knocking noise is back... any suggestions i was thinking of buying polys and some nylon threaded nuts..... any help would be great
Old Jan 26, 2006 | 10:12 AM
nytmare1's Avatar
I'd suggest torqing down the LCA bolts to 90 ft/lbs. That's the advice from UMI regarding the popping noise. That's is, provided you've not over lubed the bushings.
Marc
Old Jan 26, 2006 | 10:02 PM
Marc '99T/A's Avatar
Have been doing this since they were installed. How would over lubing them cause the clunking noise? I know my bolts are tight enough; I don't think I could get them much tighter.
Old Jan 27, 2006 | 08:57 AM
i believe over lubing them would cause them to mushroom and yes they have been clunking since day one..... yeah it blows
Old Jan 27, 2006 | 09:37 PM
I'm with you, man. It seems like every little thing you hit is going to make your car fall apart! Ahhhhhhhhhh!!!!!!!
Old Jan 28, 2006 | 09:23 AM
if i needed to get new bushings would the polys be the same as stock or is there a special number
Old Feb 2, 2006 | 03:41 PM
i think i found the problem..... i also replaced my rearend cover when i did my lca... i think the sway bar is hitting the cover... is there one that sticks out a little farther????? thanks
