LCA question
Old Mar 2, 2006 | 09:45 PM
Tkami129's Avatar
do you guys have any issues as far as rattling or noise goes with the adj. LCA's?
Old Mar 2, 2006 | 11:08 PM
_JB_'s Avatar
How hard is it to change the LCA?
Old Mar 3, 2006 | 09:44 AM
SSCamaro99_3's Avatar
They clunk a little, particularly over expansion joints. However, I don't daily drive the car anymore, so when I do i want to get the most out of it.
Old Mar 3, 2006 | 08:31 PM
227Hawk's Avatar
On a D.D. not sure i'd want Rod ends. i'd lean more towards Rubber/ Poly.
Hawk
Old Mar 3, 2006 | 11:20 PM
Tkami129's Avatar
thanks
Old Mar 4, 2006 | 12:06 AM
VIP1's Avatar
Copy & Paste Moderator
Easy as jacking up the car and removing two bolts.
Its just that one of them is a little awkward (sp?) with the body in the way (there is a notch, but after the 3/4 mark a socket wrench no longer fits).
Before removing them, make sure that both the body and the rear end are supported in the air since the LCAs hold the rear-end in the car. You dont want to support just the body or just the rear beacuse one or the other could move and pose a dangerous situation.
Here is the write-up from Install University:
http://www.installuniversity.com/ins...ca_install.htm
I installed SLP SFCs and Spohn LCAs at the same time.
Here is the write-up I followed for the SFCs:
http://users3.ev1.net/~cnl1/firehawk/subframe/index.htm
That is basically how I had my car supported when I installed the SFCs and LCAs.
Since my driveway is at an angle, i didnt have to jack up the front to have the car be level during the install.
EDIT:
Also, Do one LCA at a time to minimize the chance of the rear moving around!
Old Mar 4, 2006 | 01:36 AM
_JB_'s Avatar
Awesome, thanks!
Old Mar 6, 2006 | 10:42 PM
VIP1's Avatar
Awesome, thanks!
You're Welcome.
Old Mar 6, 2006 | 10:48 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Spohn-poly/poly.
Old Mar 7, 2006 | 12:12 AM
sidewayz28's Avatar
just ordered a package deal from UMI..tubular non adj. LCAs w/ poly mounts & non adj panhard rod...ill tell u how install goes in a few weeks when i recieve the part
