Tired of the prokit rear sag....
Is there anything I can do to get rid of this sag without changing springs? I'm tempted to just go back to the stock rears and do the heater hose mod however I'd rather make the current prokit spings work.
I don't know much about springs so I'm not sure if there is a way to fix the sag without change springs, that's why I'm asking.
A search didn't pull up anything.
Thanks!
Thanks!
Thanks!
Thanks!
1 Post
Originally Posted by John_D.
That's what I did. Worked good for me.
The front springs are where the biggest rate increase comes in.
hows the traction? (with good shocks)
Are you guys with the sag still using the stock factory rubber bushing on top of the rear springs? You might want to put them back in. That should raise it up.
If you are using it.
Try also using an additional poly spacer on the bottom perches.
By the way I have an extra new pair that I could spare.
