Koni shocks
Sorry Sam
Scott.
We get it. I was just saying that it was not fair to say "I bought all of this stuff on ebay, what would it have cost from you". Comparing new to used stuff of unknown history is not exactly fair and mostly pointless. That was my point.
There are an awful lot of us who try to share our knowledge. Not that we know it all, but many of us have learned things the hard way. It gets frustrating when people keep giving advice when they have no experience with a product. Some will say "(insert lowering spring here) springs will work great with stock shocks, you don't need aftermarket shocks", then we find out that that person has never driven a car with aftermarket shocks. So, how would they know how much better the car could be? They wouldn't. But, after 3 or 4 people say that, someone else decides to try it because "it works fine", or so they were told. Can you do it? Sure. Is it optimum? Not a chance. Many of us will go out of our way to advise that person that they'd be considerably happier with better shocks. 3 people will call us idiots, 2 more will bitch about the price, and 4 will say they have the best setup ever with those springs and stock shocks. I, and others, wouldn't be here trying to help if we hadn't learned most of this stuff the expensive way. This doesn't mean we have all the answers (nor do you have to listen), but we can often cover most of them. I never claimed to know it all, but I often try to save others money and frustration.
And I still don't think that every car on the road needs Ground Control stuff. I'm only running the rears on my car and I managed to win a regional SCCA championship on them this year (and I'm not running the GC fronts, and I don't miss them at all). Is it good stuff? Sure, is it required? No.
And I still say that most cars here qualify as drivers more than anything else (and that's not a bad thing).....
The 4th gen shocks can be adjusted while on the car, and have a little more "fine tuning"
Quality for both shocks there is no difference. I'm sure Sam will chim in and add anything I forgot
I chime in on topics like these because I'm one of the people Trackbird talked about. I bought new lowering springs and cheap shocks. Compared to stock springs with stock shocks, it really wasn't that much worse, but it also wasn't really that much better. I had no other basis of comparison, but as time went on, I became increasingly interested in improving my handling.
As for the price thing, if you can find the same parts cheaper, then more power to you. However, what Sam is saying is some companies set rules for how much less than list a part can be sold for. If the manufacturer gets wind of this happening, the company will likely not be allowed to sell that part any more. Sam isn't the type of person to go calling Koni and "tattling" on a company.
This is not a cheap hobby. But it becomes needlessly expensive when you have to do the same mod twice because you are unhappy with the results.
-Mike
The third gen Koni SA's have 4 adjustment settings. You must pull the bottom of the shock loose from the axle, reach up to the top of the shock body, push a button and twist the shock to change the settings. Then, you let go of the button, put the plastic cap back on the top of the shock body, bolt it to the axle and drive.
The 4th gen versions you simply lay down the seat, fold back the flap of carpet, put a **** on top, turn the ****, remove the **** and put the seat back up.
The 4th gens are also variable. You have about 2.5 "turns" of that **** and can use any setting in there (there are no detents, just turn it and go). So it's much more adjustable and much easier to set.
I mention this because someone, somewhere would have discovered this and then think that Monroes are the BEST! Simply a contracting job.....deCarbon's are a fine design, GM just completely messed up the valving. The Bilstein's they sell for Ford Lightnings and TRD trucks are different valvings than those two OEM's put in their "OE" Bilstein's. And on and on.
And for the record, I have a MANY customers on here with HD's @ $329 a set. If they fit what the needs and desires of the owner are, then that's what I use. Why does everyone get revved up and think I think Koni's are the ONLY option? I'm the guy who is responsible for the Revalved Bilstein's as a cost effective, but more performance oriented measure. I'm the guy that informed you all about the ability to lower with the Koni's, and that in many cases (not all by any means) extra money spent on springs was wasted if the job could be done without them.
Those of you who think I'm disingenuous and this is all a sales pitch would be wise to start reading, and reading a lot of old posts and threads. I've got a pretty damn good reputation (which I'm pround of and work hard to keep) for being the guy who tells it like it is, whether it makes me money or not. You know the saying you can please all of the folks some of the time, or some of the folks all the time? I'm rather please all my folks all the time and do less volume, than be all things to all people. If you are looking for someone who's honest and will lay it out for you, call me. If you just want a parts pusher, don't..... Your choice, but I do "get" it.
BTW, this particular mess started wtih the recommendation of coil-overs (which cost more) over springs. I feel the springs would likely be just fine, and said so. That's the *CHEAPER* option of the two, not the more expensive one.
And whille shocks aren't cheap, they are one place you REALLY, REALLY want to spend the good money on the suspension. Hence the reason I work so hard to educate folks, and not so hard pushing many of the other cheaper products that are much less effective (and often not even the right part for the job). Folks just tend to buy things based on heresay. I'm out to change that and have folks buy parts based on what they need.
I'm a customer of Sam's, and I couldn't be happier. I bought a Ground Control setup (no, he didn't push it, I asked for it) to go with the Koni's I already had. The main reason I bought from him was that the few dollars more I spent is worth it considering the fact that I get the benefit of his knowledge and experience in setting up and racing 4th-gens. I told him what I wanted to do, he gave me his recommendations for spring rate and shock settings and I bought them. I also bought a set of his custom sway bars since he felt the ST bars I liked were too heavy and too stiff in the rear. I thought that the sway bar and the spring rate choices he gave me were a little unusual (600 lbs/in sounded painful) but I took him up on it. And he was right. The car rode and handled exactly like he said it would. It's a night and day difference from my last car that I set up with X spring and X shock and chassis bracing and every control arm in the car replaced. Sam saved me the time and expense of another suspension trial-and-error session, and to me that's priceless.
While there will always be part pushers out there, rest assured Sam is not one of them. I would recommend him to everyone I know looking for suspension help. Can you find parts cheaper somewhere else? Possibly. Are they going to take the time to help you set it up and explain to you what's best and why? Don't hold your breath.
On second thought, maybe some of you should hold your breath. That way guys like Sam and Trackbird won't have to deal with so many ignorant people bitching and moaning.
Those are the two biggest reasons why you won't see GP's from me in general. I'll just flat put something on sale instead of try and work the system.
