What shocks to use with Eibach Pro kit
Old Feb 13, 2006 | 10:21 AM
3.8SFITURBO's Avatar
Default What shocks to use with Eibach Pro kit
I just got my Eibach 2" drop springs yesterday. I am not planing on new shocks, But a few people I have talked to told me it might not be a bad idea. What is the best priced decent shock I should get to use with these springs???? Thanks!
Old Feb 13, 2006 | 02:27 PM
kws87's Avatar
I am running AGX's, I like them. Others will tell you koni's, which are nice but very expensive. I picked up AGX's all around for $300. Good luck
Old Feb 13, 2006 | 02:53 PM
Toasty's Avatar
I'm pretty sure I'm going to go with revalved Bilstein's from Strano. He'll match them to what you want and how you drive for around $500.
Old Feb 13, 2006 | 04:47 PM
ls1king000's Avatar
I have talked to Sam about revalving Bilstein's and he won't do it. He strongly was against HD's on a lowering spring with a higher than stock spring rate.
Old Feb 13, 2006 | 04:53 PM
GreekGator's Avatar
I dont know where you got that info from, but AFAIK, he does Revalve Bilsteins. And he is against the HD's on lowering springs b/c they specifically are made for stock springs. HTH
Old Feb 13, 2006 | 05:50 PM
Sam Strano's Avatar
LS1TECH Sponsor
Huh? That's news to me.
I won't revalve used shocks. There are certain springs that I feel the only thing to use is Koni's due to spring rate.
But I do Revalves all the time. You're thinking of plain HD's (which Revalves start as), and are not meant for lowering springs.
__________________
Old Feb 13, 2006 | 08:10 PM
ls1king000's Avatar
Opps ......... sorry Sam I misunderstood. How much difference is there in rate Pro kit compared to stock? Do alot of people go with SA Koni/ Pro KIt for even a lower ride level without much higher spring rate?
thanks
Old Feb 14, 2006 | 09:53 AM
Sam Strano's Avatar
LS1TECH Sponsor
Stock is about 292/115-ish. LS1 Pro-kit (and that's key, because LT1 Pro-kits are very different) are 400/80-137 rear (but really more like 120-137 working rate). So while the rear isn't hugely stiff, the front is around 25% stiffer.
Pro-kit wtih the lower perch on the Koni's is absolutely not recommended. Actually the lower perch is only for stock height springs. You will damage something, and likely not be able to drive anywhere without dragging something, somewhere.....
__________________
Old Feb 18, 2006 | 12:35 PM
RelentleZ's Avatar
so sam.. you suggest using the stock spring with the ls1 prokit?
Old Feb 19, 2006 | 07:05 PM
killerbeez's Avatar
Bump, I'm interested too. Stock shocks are better with the prokit? (isn't that what you're asking?)
Old Feb 20, 2006 | 11:21 AM
Sam Strano's Avatar
LS1TECH Sponsor
I don't follow the question. First off, you can't run stock springs with the pro-kit, as those as springs too. Maybe you meant stock shocks with the pro-kit???????
HD's are better than stock shocks to be sure on a lowered car. But better does not equal correct. And the stock shocks are so poor, the little shock on you screen door at home might be better.
__________________
Old Feb 20, 2006 | 03:40 PM
Strokinit383's Avatar
I think im going to follow this thread.
Old Feb 21, 2006 | 12:52 AM
01RedZ28's Avatar
I'm confused. All i know is i have the prokit and revalved bilsteins which i bought from strano and very happy with how the car rides and handles.
Old Feb 21, 2006 | 07:58 AM
Superman09's Avatar
LS1Tech Sponsor
First of all, i do not believe the Pro Kit is a 2" drop, that is the Sportline kit i believe. Which one do you have? I have the sportlines (2 inch drop) and am curious about some decent shocks for it for daily driver. Or maybe i got it mixed up? but i think prokit is like 1.2" drop and sportlines is 2"
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Feb 21, 2006 | 10:17 AM
Sam Strano's Avatar
LS1TECH Sponsor
Sportlines are lower than Pro-kits. They are listed as approximately 1.6"f/1.4"r, and 1.2" lower respectively. Note the word *approximate*.....
Pro-kits tend to be about 1.5" lower, and Sportlines are usually around 2" lower in the real-world.
__________________
Old Feb 21, 2006 | 11:48 AM
GR33N GoblinM6's Avatar
Mods you need to make this "what shocks for pro-kit" a sticky on this board.. it comes up at least 2 times a week..
Old Feb 20, 2008 | 10:46 AM
1fastcamarosss11's Avatar
so best shocks for sportlines?
Old Feb 20, 2008 | 10:56 AM
hpjunky98's Avatar
Sportlines are crap.
Options for lowering springs are:
KYB AGX: Allows adjust ability and is the cheapest shock that can dampen a lot of lowering springs, just not that well. The shocks adjust rebound and bound settings at the same time, which isn't optimal for tuning.
Re valved Bilsteins: HDs used to be the go to shock for alot of folks on here, but the HDs were changed to behave more like factory decarbons, so re valves are the only real option. Unfortunately, Bilsteins are on backorder, so unless you want to wait you might was well save up for a better option.
Konis: Allows a wide range of rebound only adjustability and will make factory springs ride like a German sedan, and lowering springs handle like a true sports car.
Old Feb 20, 2008 | 11:37 AM
00bluews6's Avatar
get QA1 12 way "F" and call it a day
Old Feb 20, 2008 | 11:38 AM
00bluews6's Avatar
with a prokit
