Walkthrough For Installing Springs?
Old Feb 18, 2006 | 01:22 PM
killerbeez's Avatar
Default Walkthrough For Installing Springs?
Hey is the a walkthrough anywhere for installing springs?
thanks
Old Feb 18, 2006 | 01:50 PM
chupr0kabra's Avatar
Front:
http://www.ls1howto.com/index.php?article=6
Rear:
http://www.ls1howto.com/index.php?article=8
-Mike
Old Feb 19, 2006 | 03:43 PM
The PAT WS6's Avatar
rears are a piece of cake on the other hand the fronts are a PITA gettin the assembly out from the lca in the front just use a pry par and hammer and an extra hand and you shouldnt havea problem
Old Feb 19, 2006 | 05:16 PM
Screamin_Z's Avatar
I hated changing the front springs, I'll never do it again. I HIGHLY suggest taking it somewhere to get that done.
Old Feb 19, 2006 | 09:19 PM
OOZ28's Avatar
Anymore info?? Im trying to get the spring off the front, I already have everything out, I just cant take the spring off.
Old Feb 19, 2006 | 09:56 PM
Screamin_Z's Avatar
spring compressors, big wrenches to pry the coils to get the spring compressor out of the spring and a small mallet to hit the wrenches.....good luck
Old Feb 21, 2006 | 03:00 PM
joblo1978's Avatar
The front passenger side is the bitch. Extra tools I needed were various grinders, multiple cutoff wheels, vice, 4 lb. sledgehammer, lots of penetrating lube. I ended up cutting the shock into about 5 pieces and the stock spring in two trying to get the hat off of the shock. The two parts had fused together. Would have gotten the whole install done in 3.5 hrs. if it weren't for that.
Old Feb 22, 2006 | 12:47 AM
Screamin_Z's Avatar
yeah, we cut the strut itself to get that fvcker apart...passenger side like stated above. those damn nuts were so fvckin rusted, we even used penetrating lube...let the nut sit in a puddle for about an hour and it still didn't work. so we torched it off and that solved the problem.
Old Feb 22, 2006 | 09:11 AM
robertbartsch's Avatar
The JMX web page has a very good explaination of the spring swap. See below.
Old Feb 23, 2006 | 10:58 PM
RelentleZ's Avatar
help!! i am doing an install right now... i bought a set of gabriel shocks to go with my eibachs. the bottom tray on the gabriel is too small for the spring to set in. what now?!!
Old Feb 24, 2006 | 10:58 AM
2000Z28M6's Avatar
take them back get $800. Konis ..........
J/K !!!
na seriously just get sum that do work with your springs.
