Question on Bilstien Shocks...
This assumes you have stock springs, and are looking for a good all around competent car. Neither is a what I'd consider the best handling. The HD's are simple a better match for the stock springs IMHO. *IF* the SLP's didn't have less compression, I would use those before HD's because I prefer a bit more rebound control. However, the loss of compression rate (which controls unsprung weight) trumps the desire for a touch more rebound damping when stock spring are involved.
Far smarter to run the shock with the more appropriate valving. Unless of course you don't give a lick about the car actually being a piece of machinery that has a job to do, and think of it more as art.
The SLP shocks are valved to match up with the SLP Eibach springs which were part of the level 1 package. If the car came with those springs OE, it'd also have the SLP shocks already installed.
I say HD's, all the way. Better match for your spring rates, cheaper too. And look just the same as the SLP's. Nobody would ever know anyway.
Besides only Level 1 cars had those shocks, and you don't have the spring to match.... though you could buy those as well. www.stranoparts.com --814-849-3450
