rotors warped?
Old Feb 21, 2006 | 11:06 PM
chrisryn64's Avatar
Default rotors warped?
About 2k miles ago I changed out my front brake pads and had all 4 rotors machined. After maybe 500 miles they started making a "pulsing" sound. I figured maybe it was the pads wearing in but it is still happening, and sounds like it's getting worse. My first thought is uneven rotors but they should be fine, the guy evened the surface. What do you think it is?
Old Feb 21, 2006 | 11:08 PM
FloydSummerOf68's Avatar
Have you machined your rotors before?
The more you do it the quicker they will begin to warp because there is less material left on the rotor.
It is completely possible to have a fool machine your rotors poorly also.
Old Feb 21, 2006 | 11:17 PM
chrisryn64's Avatar
the rotors don't seem to be worn away from too much machining, maybe I will try to swap the back to the front
could it be something wrong with the pads?
the guy that did it seems legit, he's been doing this stuff since the 50s
Old Feb 21, 2006 | 11:20 PM
StripedZebra's Avatar
Im pretty sure you cant swap front to rears...the fronts are bigger. Thats howmy car is anyway, i cant imagine it being any different on LS1 cars...?
Old Feb 21, 2006 | 11:22 PM
T-rex's Avatar
You can't swap rotors front to rear.The rotors are not the same size.Sounds like to me your rotors are shot.
chrisryn64's Avatar
You might be right
The rotors in the front don't feel warped but I guess even the slightest uneven part can make this sound.
Old Feb 21, 2006 | 11:36 PM
VictorT's Avatar
Originally Posted by chrisryn64
You might be right
Did you have the rotors turned on the car or were they done off the car on a brake lathe?
Old Feb 21, 2006 | 11:38 PM
chrisryn64's Avatar
done on a brake lathe
Old Feb 21, 2006 | 11:44 PM
VictorT's Avatar
Were they marked, and put back on the hub the exact same way? It is usally better to leave the rotors on the car to be turned since it will true up any imperfections.
Old Feb 21, 2006 | 11:45 PM
chrisryn64's Avatar
That I couldn't tell you. Unfortunatly I'm away at school so my tools here are very limited.
Is Midas a good place to have this looked at or should I take it to GM
Old Feb 21, 2006 | 11:50 PM
VictorT's Avatar
Well, that is hard to say. It is kind of curious because usually you wont feel a problem with stock calipers, but I am thinking that the rotors went on in a diffrent way than they were before. I would ask someone to check the run out, and if it is too much, then have the rotors turned again on the car. Good luck
Old Feb 22, 2006 | 08:32 AM
robertbartsch's Avatar
I bought new rotors and when I tried to install them they did not fit. I had my stock rotors turned down and they have been good for over a year. I think you can only turn them once, any more and they are too skinney and will warp.
Since new rotors are not expensive, I suggest you get a new set of rotors for the fronts.
