Subframe connectors: 2 point VS 3 point(triagular/diamond) worth the extra cash?
If you are mounting the TA to the floorpan, you really should consider 3 points as now the stress from the torque arm is now transfered from a factory proven "strong point" to a now thin spot of the monocoque, otherwise 2 point will suffice. If you aren't doing heavy drag racing, then you can guess what I am about to say.
