brake pad install
Any tips on what i would need and a quick write up, i know its easy but i just want to make sure there isnt anything special i need to know, thanks!
Remove wheels.
Two bolts hold caliper.
Make sure you tie up the caliper so it does not fall. I used a bungie to the spring.
Take a C clamp and gently compress the piston in the caliper so that it will fit over the new pads. For the fronts, I used an old pad so that I could compress both pistons at the same time.
Place the new pads in, just like the old ones came off.
Re-attach the calipers.
Use brake cleaner to clean rotors.
Put wheel back on.
When you get in car, pump the brake a few times. Be careful, you may not have full brake pressure when you first take off. After a few pumps, it will be back to normal.
I would also take the old rotors down to a gas station or parts store and have them turned flat. Why bother doing a brake job if your rotors are scored and warped?
Oh well all is good now
