where can i get rear air bags???
will they acually raise the car any? or just make it stiffer so it wont compress? where can i get them and how much are they. im wanting them to help my rubbing problem from the tire hitting the fender, oh ya and they help traction! i would like to be able to adjust them a little. (raise them)
"Solve your suspension problems.
No matter what you drive, Air Lift 1000 Load Assist rear spring kits can solve your suspension problems. These air springs are inflatable air cylinders made from tough polyurethane material, and fit inside your coil springs to add up to 1,000 lbs. of leveling capacity. Each cylinder has an inflation valve, so you can vary the air pressure to level your vehicle and compensate for uneven loads. Load assists reduce roll, sway, and bottoming out, and are available for most cars, trucks, and minivans with open coil springs. They come complete with air lines, fittings, brackets, and mounting hardware."
I believe they make these to fit our cars and they cost around $70.
I bought mine on line for about that price.... I tow a trailed with my Z28 and my cars lowered so I wanted to make sure I didnt bottom out..They will and do lift the rear of the car...which obviously changes the suspension action..but since I only have them inflated when Im towing ( I keep 5lbs in them Vs 12 when towing gives me a 1" lift) it doesnt matter
Check sites that sell trailer hitches etc....
LS1TECH Sponsor
We carry them....
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
www.stranoparts.com is not working.... 6/1/2006 is there any other place that i can see what it looks like?
okay.. it up again....
LS1TECH Sponsor
They aren't on my site, I can't possibly have all the parts I have on the site. Are you wanting to just look at them? If so www.airlift.com. Just call to order.
__________________
OK Sam - let's lay off the Jack Daniels while at work
That's a link to a company that sells soft sided carriers for oxygen bottles
It's http://www.airliftcompany.com/new-index/Frameset.htm
-Jay-
-Jay-
LS1TECH Sponsor
Thanks for the catch..... I hate web addresses. Never as simple as it should be.
__________________
