Rear caliper metal shims
2001 Trans Am.
Does anyone have close up pictures of how the metal shim/spring looks
when it is correctly installed on the rear caliper/pads (see image)...?
This shouldn't rub on the piston/seal, should it...?
Thanks.
Thanks.
It snaps up into caliper slot, but part of it seems to rub on the piston seal.
I was hoping that if someone had their rear calipers off if they would snap some closeup pictures showing the detail of this.
Thanks, PM sent, take your time.
If you're pulling the rear calipers off, can you also include a pic looking into the caliper so I can see the piston and seal and the clip in place.
Thanks again.
Joe
Thanks again.
Joe
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
