GMS vs BMR K member
GMS vs BMR K member
Whats goin on guys, i want to pick up a lightweight k member for my SS...
The only difference i see between the two is what is advertised as a 5 lbs weight difference, bmr 24 - gms 29.
I need some info and some opinions, and if theres another k member on the market, i'd like to know what my options are before i buy one, the stock one is cracked near the a-arm, and i figured i might as well lighten up the front end instead of replacing it with another stock one.
thanks in advance!
thanks in advance!
ok i guess i should have searched a little more, seems like the welds are breaking on the BMR piece...but i don't see anything about the gms piece.
Anyone know how much a stock k member weighs? I noticed spohn sells solid motor mounts, they claim that saves about 20 lbs alone over the stock mounts, so maybe the difference can be made up there while keeping a strong structure, plus its a cheaper route.
any opinions at all? thanks
Moderator
UMI supposedly is working on a piece stout enough for
street duty. I'd read the fine print on the GMS one, if
you can find any. BMR used to claim theirs was street
duty capable but doesn't anymore, now you see a
disclaimer instead. In my opinion GMS plays pretty loose
with their claims on other products and you should be
careful there. Take any disclaimer seriously, they're
trying to tell you something. Like "Pothole, snap!, ouch!".
