View Poll Results: Get ride of abs stuff or keep it?
ABS delete
33
50.00%
Just line lock kit
33
50.00%
Voters: 66. You may not vote on this poll
Line lock kit and delete abs?
Old 10-16-2006 | 10:37 AM
  #41
Doc's Avatar
Doc
Originally Posted by Camaross124
man **** that thing is bomb as ****... did you just buy the button from GM? i was thinking about just setting a switch next to my vert top switch like that for line lock...
Try some of the Fbody salvage sponsors ---------->
or the stealership...
I originally wanted the vert button part of the panel for the QTP cutout, the line lock for the TCS, seeing how both are momentary, it just made sense. Since I don't have ASR, I am using that button as a NO2 arming button.
Old 10-23-2006 | 11:59 PM
  #42
Gun5's Avatar
Originally Posted by PurEvl
be prepared when you do the abs delete block, you will have a service vehicle light on and the brake light on all the time too. I have my abs deleted with the block as well
the SES light will come on? I have all my ABS stuff disconnected mainly and dont have it Im leaning towards a !ABS /line kit
Old 10-25-2006 | 09:47 AM
  #43
PurEvl's Avatar
Originally Posted by Doc
On the ABS connector make up a jumper wire (about 1 1/2") with soldered ends and insert one end into pin 7 and the other into pin 12. The ABS module provides the logic ground if the system is ok. So just ground out that pin 7 to 12 (grnd) and bingo.
um that might be ok for your car but on my 2001 7 and 12 are blank or is that correct?
Old 10-25-2006 | 09:49 AM
  #44
PurEvl's Avatar
no not service engine soon...service vechile soon...my codes are all brake related.
Old 12-03-2006 | 10:48 PM
  #45
MeentSS02's Avatar
Kleeborp the Moderator™
Well crap...I haven't had time to try this yet, but it doesn't work? Great...figures 98s would have a different ABS harness too...they already have funky PCM wiring.
Old 12-17-2006 | 04:17 PM
  #46
1999 SS's Avatar
a cheap way to get rid of the abs & brake light is to pull the cluster and take out the gauge overlay and put black tape over the those two so light doesnt shine through them anymore.
Old 12-24-2006 | 01:34 PM
  #47
Doc's Avatar
Doc
If you go that far then why not just take it one step further and pull the cluster apart and pull the offending bulbs? Admit it, tape just looks cheap.
Quick Reply: Line lock kit and delete abs?
