SFC, which is the best
http://www.umiperformance.com/images/2004b.jpg
Ryan
if you've ever had experiences with a low mileage 3rdgen, even an 83 Z28 (under 20k), you'd know that even those were very stiff originally, and when you put SFC's on them, it basically preserves the car. I can guarantee stock for stock, a low miles 83 Z28 with no SFC's would handle better than a 100k mile 92 Z28 with SFC's and a suspension with similar aging ...
the 4thgen is no different when it comes to this.
and as was said by Ryan, the 3 point preserves more than just overall stiffness.
when I was a 3rdgen owner I was hoping somebody would do a 3 point similar to that, but as a 4thgen owner currently, I'm very happy with that offering, and fairly soon I intend to purchase said 3 point UMI
i've read a lot of things about how SFC's don't make a damn bit of difference on a 4thgen, but in reality, its bullshit. They'll help in the long run
We were running Eibach Sportlines before i put in the SFCs, and once i bolted them in, the ride completely changed. It rode better, and the car felt soo much better.
I went with bolt-ons because I want the Hawk to be original if need be. They really tightened the car up and were a good mod and I am happy.
Very heavy, strong, boxed... these will last forever. No skimpy little 2 pt tube like most others, this thick boxed 3pt deal is the best aftermarket part SLP has ever made. Better than the Kenny Brown DD. (stiffer)
These are the only SFC's I'd consider if I had to do it again. Worth every one of the extra 45 lbs of dead weight to haul around.
and i figured they all work the same.
