Koni SA users: how's the ride like at full soft with the factory springs?
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
With my '02 Z28, I'll be doing 95% non-spirited (mature) street driving and 5% drag racing. I want to keep my factory Z28 springs. I want the Koni SA's for the front so that I can use its lower spring perch. I'm also extremely lazy and don't want to play with the Koni SA settings. I just want them at full soft. How's the ride like at full soft with the factory springs? Are they already at full soft from the factory? Does anybody know how much they cost as a set with 3rd gen Bilstein HD's in the rear? Thanks in advance for the info.
No, its not that bad at all. I drive with mine on full soft or near full soft almost all the time now. I think the stock springs make it not get quite as soft, but I don't know too much about this. I do know though that I wouldn't mind getting springs that let them get a little softer for drag racing. They drive great this way though...you lose a little stiffness/handling, but get better ride quality and better weight transfer on launches.
Originally Posted by Urban Legend
I do tell you that with the G2 Supersprings and full soft it feels like you are driving around in a car with cut springs. At night the headlights will be bouncing up and down. So I say it can only be worse with factory springs.
But maybe I am wrong.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Stiff springs require more dampening in the shock. I also have G2 springs, and run 5 sweeps up front, and 1 turn un the rear (both from full soft). Ride is nice and handling is great.
Stock springs are softer and require less dampening. I would guess that full soft with stock springs would be close to the DeCarbon ride, but with better spring control. In many ways Koni's ride better than the stock shocks.
Originally Posted by damon_Z
That's what I want. There's no doubt in my mind that better ride quality and better weight transfer is more important than stiffness/handling when the car is used mostly for street driving and occasional drag strip use. It's not like I'm gonna go drift racing, autocrossing, road racing, or doing something stupid like taking public street corners or highway ramps at 80 MPH. What settings were your Koni SA's on right out of the box?
98_1LE - you are right. If I had to do it over again (or I might change it in the future) I would upgrade the springs as well. The ride is fine, as the Konis are much better than the stock DeCarbons, but I'm not getting the full softness that I would like. Ideally, and I know this isn't possible, I would like them to loosen up like a drag shock on full soft, and on full hard (or close to it) be like it is riding now on full soft. I don't know how to get this done though. I just don't need the hard setting because I don't autocross, but I like the reliability of the Konis (and ride quality) vs a gas shock, which is why I bought them.
Does anyone know how I could come closer to getting what I want out of these shocks? Like maybe changing springs, etc?
Sold The Fun Stuff :(
Originally Posted by 98_1LE
Sadly you are ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
If you want softer than what you have you might look into the SLP Level 1 kit with the SLP Eibach springs, SLP Bilsteins, 1LE front bar, PHB & LCA's. Or just get the springs.
The front bar generally does not affect ride, unless one wheel is loaded and one is not. Basically going over a speed bump, the bar is free to rotate as the suspension is evenly compressed, but if one wheel hits a pothole and one does not, the sway bar is twisted adding to the effective spring rate.
That said, other than shocks, a huge/stiff front sway bar is next best handling mod besides race tires or a pro driver.
Didnt read what the others said but Koni's are simply waaay better dampers than stock shocks. They really do perform better and ride better... simultaneously... rare that you dont have to compromise one for the other... but thats why they cost more.
Matts22
please dont tell people to konis as drag shocks. U dont like them dont tell other to use them.
Damon
If you want a drag car use QA1. If you want the car to handle use the konis. The rate is to high on the konis to transfer weight.
Damon
Originally Posted by YellowToy/A
Matts22
Damon
Damon
Don't accuse me of stuff I didn't say, or you're gonna **** me off.
