Torque arm bushing
Old Apr 18, 2006 | 11:14 AM
99M6Z28's Avatar
Default Torque arm bushing
I was under my car this morning replacing the rear shocks since I had a little wheel hop and vibration under accel in first and second. Anyway, I got to checking out other stuff while it was on the lift and noticed that my torque arm bushing in in 3 pieces!! I didnt know it could break like that. Anyway, where can I buy a replacement? Should I buy poly? Also, should I replace the tranny mount while I am there? The shocks dractically helped the wheel hop and vibration but I think this will solve the issues!
Old Apr 18, 2006 | 12:46 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Are you talking about the stock torque arm bushing (a.k.a. the clamshell)? If so, it came from the factory in two pieces (could look like 3 I guess if you looked at it right). They just kinda sandwich together...works quite well actually. I only ask because you don't list an aftermarket torque arm as one of your mods...
Old Apr 19, 2006 | 12:45 AM
99M6Z28's Avatar
Yes, It is the stock bushing. It looks all torn up. Is this common?
Old Apr 19, 2006 | 02:48 AM
blown 346's Avatar
If it is all tattered than no it isnt normal, and I would replace that and your trans mount with poly urethan mounts. They will last longer but can also bring more vibration to the ride since they wont absorb it.
