Cracking rotors...
Thanks.
Thanks.
Here's a great thread to research this:
https://ls1tech.com/forums/suspension-brakes/353903-brake-faq.html
BTW, what brand of rotors are they? and how long have you had them on the car?
BTW I'm going to Autozone today to get the cheapest rotors I can find to hold me over until I can get good replacement drilled rotors. They are backordered on TireRack
.There are no drilled rotors I'd really call "good" replacements (the Porsche drilled rotors hold up quite well, but they are about the only ones and they won't fit our cars without buying an expensive brake kit). Just get good blanks and run them. You'll crack the next set of drilled rotors just like you cracked this set. It's common.
https://ls1tech.com/forums/suspension-brakes/435436-do-i-really-need-cross-drilled-slotted-rotors.html
...and this one:
https://ls1tech.com/forums/suspension-brakes/477787-need-help-explain-slotted-drilled-rotors.html
https://ls1tech.com/forums/showthread.php?t=435436
...and this one:
https://ls1tech.com/forums/showthread.php?t=477787
...and this one:
either I smell someone's fancy cross-drilled brakes being bedded in only to crack, or it might actually be the placebo effect of a thread closure.
