how to install Energy Suspension Transmission mount?
I need to figure out how to put the Energy Suspension Transmission mount in.
http://www.lmperformance.com/3119/7.html
that is excatly what I have. The instructions are worthless. I need to know if I need to use that stupid metal bar and where the hell do the washers/lockwashers go.
btw I think the metal bar touches the tranny but if I don't put washers inbetween the poly mount and the metal bar the metal bar isn't flush becase of the stupid bumps on the poly mount.
help!!
help!!
The plate goes against the transmission. The bolts go through the washers/lockwashers, the mount and then the plate (and into the trans). You tighten everything down and the metal plate will "pre load" the mount (then it will sit flush on the trans). Install the cross member and bolt it to the mount.
Drive the car.
Drive the car.
The following users liked this post:
Slayer91 (12-04-2019)
99, camaro, energy, guide, install, installation, installing, ls1tech, mount, plate, preload, suspension, tranny, trans, transmission
