Time for brakes!
#41
Hey guys I just wanna say thanks for helping me out with everything! My wheels where put on today so now I will have to invest in the brakes, I think Im gonna kick it around alil bit but I'll more then likely go with the C5 Rotors. Thanks again, - Frank
#42
HP Pluses are *not* suitable for sustained track use, they are not race compiund pads and I'd fully expect them to fade away, especially on a small track with little time between corners for cooling. A larger rotor can help here a bit, but very little if the compound is still the same.
I have to reiterate that I feel your friend's case has more to do with the pad choice/track than the 12" rotors. And he in all likelyhood has to brake harder than a car on r-comp tires. The biggest difference is in lateral grip, not accel/decel grip (though there clearly is there as well). Hence a car on street tires can't carry the corner speed a car on race tires can, and has to slow down more.
Maybe I missed what tires you were on for the test, but R-comps do help some. I'm betting the Viper wasn't on those. And they use only a 275 front tire vs. your 315. Given we don't run huge amounts of negative camber, we still end up with more tire on the ground under really hard braking than the Viper does.
#43
Now, if you really what some good braking,,, get you some drilled rotors for the front and rear. Get a set with the most holes for better cooling. Combine that with some Ceramic pads from the local Zippy Parts and you will be all good!
