WTF...frozen rotors?
I'm bored so I'm just looking around on the net and found this...NEVER heard of frozen rotors.
http://www.tirerack.com/brakes/brake...ar=&perfCode=P
Frozen Rotors® by Diversified Cryogenics, Inc. The name says it all. Frozen Rotors freezes brake rotors...rock solid. Rotors are frozen at 300 degrees below zero using a deep cryogenic process that permanently changes the atomic structure of the rotor. This proprietary, 60-hour cryogenic process permanently and dramatically improves the usage life and stability of brake rotors to create a distinct advantage in tensile strength, abrasive wear-resistance and rotor longevity. As a result, frozen rotors deliver increased performance and a higher level of safety while significantly reducing braking system costs.
You should get out more. This has been around for several years now. The Frozen Rotors brand has been around for about 2 years I believe. There's hardcore racers that have their blocks and heads cryo treated. Maybe when I'm in the market for new rotors I'll look into these more.
