ABS INOP and BRAKE light after rear swap.
Pop the hood and pull all the fuses for ABS. I think you will find 4 (2 little ones and 2 big ones). Leave them out for a few minutes. When you put them back in, take it for a quick spin for the abs to re-sync. Did you disconnect the brake lines from the calipers? If so, bleed the brakes. If this doesn't work, check the wiring and the air gap between the sensor and the reluctor ring. I believe the gap should be between .010 - .015. I guess it is also possible that the reluctor ring was not installed. You will know when you pull the cover. Hope this helps you out.
