Spohn Torque Arm
Old Jun 10, 2006 | 09:59 PM
wrencher's Avatar
wrencher
Originally Posted by TAGOES11S
Yep I broke it. 1.42 60 with a 6 speed. PS Spohn stood behind there product. I just had to pay for the new slicks that got cut down in the process and the yoke that twisted when it pulled the driveshaft out of the tranny.
That is exactly how mine broke. Same place & conditions.
It did alot more damage to my car though. The pinion yoke the drive shaft the main shaft of the trans all had to get replaced
Alston going in soon. This one will be for sale........
Old Jun 24, 2006 | 01:39 PM
damon_Z's Avatar
Sorry to hijack this thread.
For the torque arms that snapped, were they the transmission-mounted torque arms or where they the crossmember-mounted torque arms? Thanks in advance for the info.
Old Jun 25, 2006 | 01:04 AM
wrencher's Avatar
wrencher
Mine was a crossmember/G-load brace with poly mounts.
Old Jul 1, 2006 | 04:26 PM
2000zrocks's Avatar
the bolts loosend up on mine and broke the mounting plate. i just bent it all back
into shape and welded it back together. needless to say i check the bolts more often now!!
Old Aug 17, 2006 | 02:26 PM
TAGOES11S's Avatar
Anyone know what would cause the stress at this point of the TA? I had spohn send me another one and after 3 passes cutting only 1.5 60's I see 3 cracks where this one broke. I run the pinion set at -3. Rest of the suspension is Sphon LCA's, Sway bar, BMR panhard, QA1 shocks, BMR LCA location brackets, Denny's DS. I launch at about 5K on 28" ET Streets.
Is it the TA? or do could I have something setup causing a bind here?
Old Sep 13, 2006 | 11:35 PM
WARPNOVA's Avatar
Where the TA's that borke made of Chromoly or mild steel. This is the exact arm that I am looking at for my 12 bolt but am now kind of worried. Any further input would be nice. Thanks.
Old Oct 27, 2006 | 10:14 AM
cam's Avatar
cam
I'm curious too anyone have updates on this?
