Info on How to Lower?
Since I was going to be in there anyway replacing the shocks I figured I would see what is needed to lower it. Nothing radical but there is just way to much wheel well, and at the last show I came real close to winning the 4x4 award.
Currently I have bfg kdws 275 40 ZR17s on ZR1 17" rims. I don't want to change the rims, and do know that these tires have more sidewall then the KDW but the dang KDW get a flat spot if parked for long periods. I fly around the country a lot and drive my truck instead of the SS to work so it sits for weeks at a time.
So there's the background. Can anyone give me an idea of what is needed to lower this? I haven't even attempted something like this before so I have no idea what is needed. Picture below shows how much room there is between the wheel and fender. Its 3" from Fender to Wheel in the front and 2 1/2" in the back. Is 1" - 1 1/2" enough clearance?
Thanks in advance for the help.
If anything maybe this could become a sticky on how to lower your fbody
Also be sure to mark how the stock springs fit onto the shocks. This is something that isn't mentioned on that guide but it cost me a lot of time. You have to have the spring turned and aligned on the shock for the upper mount to fit back into the fender. This in turn will make the bottom of the shock mount correctly to the lower mount.
Also a second or third set of hands make it A LOT easier to handle.
Just to let you know I was in the same position as you were with not ever attempting this. I just read the guide over and over again and I'm happy that I did do it.
I had also never done this before, but I had the help of two very knowledgeable friends which made everything much easier. If you decide to do the install yourself and have more questions just ask. Good luck! Last edited by BAD99TA; Jun 13, 2006 at 02:56 PM.
