sportline kit installed now some issues?
Originally Posted by C Murda
wait...what from ground control am i actually looking for? coil overs? i was thinking of weight jacks but the ones im thinking of i cant see working on our 4th gen front suspension....i was thinking of the weight jacks that 3rd gens use.....?
![](http://img.photobucket.com/albums/v486/Carlos01SS/12108bab.jpg)
The ERS front springs are linear, these are 500# fronts...The Koni DA springs shown needed to have the upper "hat" grounded down in order for the ERS front springs to fit over the shock--Sometimes folks can loosen the bolt that holds the upper damping adjusting hat, but Guldstrand Motorsports in Burbank spent 2 hours trying to loosen it to no avail, hence the necessary grounding of the front shocks...
Notice how the red springs are sitting on a brass lip that you unscrew to raise where the shocks rest, this is how you raise/lower your car. Every time you adjust ride height in the front, know that you'll have to get a front alignment, so keep that in mind...
The rear ERS springs are basically the Eibach Prokit springs, progressive @150#, they set like regular atermarket springs, but notice the brass lip that sits on the threaded red aluminum sleeve, that's how you adjust the rear...
![](http://img.photobucket.com/albums/v486/Carlos01SS/50247d8d.jpg)
If you order the GC Coilover setup, the rear springs will not be powdercoated, I had the fronts & rear done at the same time so they're the same color...Most people wouldn't worry about it, but I did.
The factory ride height(well, MY factory ride height) is about 27-3/4" front & 27-1/2 rear, when Guldstrand did it initially it was 24-1/2" and it was WAY too low, I was scraping into everything, BAD CALL.
Now fronts are 26" even & 26-3/8" rears, and it's still a bit low...
Be careful what you ask for. Too low will be a horrible ride.
well i wanna be low and i want a firm solid ride.
These demands are nothing new in the department of wanting to turn the vehicle into something that's not just possible with a majority of the available aftermarket equipment.
