Something making a banging noise
Old Jun 10, 2006 | 03:41 PM
victimizati0n's Avatar
Default Something making a banging noise
When i hit potholes and stuff, i can hear something making a banging noise. It sounds like it is in the front drivers side, so im figuring it is the shocks or something?
Is there anything else it can be?
If it is the shocks, are these a good brand: http://cgi.ebay.com/ebaymotors/FRONT...QQcmdZViewItem
thanks for your help
Old Jun 10, 2006 | 10:57 PM
kruthes1's Avatar
It is most likely your strut on the drivers side.
Old Jun 11, 2006 | 08:26 AM
how much will it cost to replace/fix?
Thanks
Old Jun 11, 2006 | 10:29 AM
chupr0kabra's Avatar
I'd be more inclined to believe it's something other than the shock (it's a shock, not a strut). Take the wheel off and look around in there for anything that looks out of place. Are the sway bar end links intact? Is the upper ball joint in good shape? Someone on here described a similar noise recently and it turned out to be the ball joint. Are the tie rod ends in good shape?
-Mike
Old Jun 11, 2006 | 11:00 AM
-Mike
Thanks, ill have to check.
The car has 94000 miles on it, so it can be anything.
Old Jun 11, 2006 | 11:15 AM
Bearcat Steve's Avatar
What mods to you have?
Old Jun 11, 2006 | 11:20 AM
none.
Old Jul 1, 2006 | 11:06 PM
30thanniv's Avatar
I had similiar noise issue. It turned out that the caliper had side to side slack. I shimmed it up with a washer. Take the wheel off and check it out
Old Jul 1, 2006 | 11:48 PM
Duffster's Avatar
had a similar noise. . .was the torque arm hitting the top of the tunnel because a nut came off the torque arm mount up top. . .
