Shock tower nuts
Originally Posted by coolformula
5/8 and I used a rachet wrench...
I believe the thread is 10MM * 1.5 pitch but you will need to check to be sure.
I had to replace both shock tower nuts as I recently did a shock/spring swap on my car. I installed Koni shocks and I think they have the same thread size as stock shocks. When I replaced the nuts I indeed purchased 10 MM X 1.5 as Weezzer stated.
Hope this helps.
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
Hope this helps.
These are the ones that must be timed with the lower shock tower assembly in order to attach the strut to the vehicle correctly.
