Spohn Torque Arm Installed *pics*
Old Jun 13, 2006 | 01:51 PM
Red97Z's Avatar
Default Spohn Torque Arm Installed *pics*
Here she is, bolted right up, feels a lot tighter now, even if it does pop the floor under hard acceleration.
Old Jun 13, 2006 | 01:55 PM
bmfcamaro's Avatar
they are nice, but you have to give the floor pan by the rear some business (BFH) to get that to stop happening.
Old Jun 13, 2006 | 07:29 PM
CW00BlackTA's Avatar
Or, you can just drive it and it will make room for itself after a few hard bumps. Looks nice.
Old Jun 13, 2006 | 07:58 PM
keliente's Avatar
Holy pinion seal leak batman
I just took my torque arm off. God I hated that thing.
Old Jun 13, 2006 | 09:10 PM
Red97Z's Avatar
Yeah, I had that fixed when they installed the torque arm, new seal and fluid, I was bone dry!
Old Jun 14, 2006 | 12:52 AM
RrCoX22's Avatar
nice... pics means plural ....give it some time to break in for a couple months then bumps and rattles should be minimal
Old Jun 14, 2006 | 07:58 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
Never had a problem with my Spohn T/A hitting anything under the car - I still get a thump from it though every time the car shifts.
I was told by Spohn that this is 'normal' and it comes from the lever style front mount they use instead of the sliding stock style mount.
Old Jun 14, 2006 | 10:08 PM
TheBlurLS1's Avatar
That's what she said...
I bet a poly trans mount would fix the body bumping.
Old Jun 14, 2006 | 10:42 PM
koji777's Avatar
it's actually hitting the car where it bolts to you diff...... look up there you will see that you only have an inch or so of travel.....the dent/scuffs make the point of impact very clear
Old Jun 15, 2006 | 09:22 AM
jerflash's Avatar
i just let mine make its own room and its fine now
