325lb springs too much for drag racing?
Devil Dog, OohRah!
I keep meaning to ask this question, and since there is a sale on, I guess now is a good time to do it. My Z28 has single adjustable QA1 shocks at all four corners, and 325lb springs in front. Are these too stiff for street, and as much drag racing as I can do when I get home? Or will they be fine with some more power?
Also, what settings would be good for everyday and track. I was thinking 6 front and 4 rear. What do you think? Thanks in advance.
Devil Dog, OohRah!
Bump to the top before bed. Too elaborate, I went on the BMR website, and they recommended 275 for drag racing, 300 for DD and 325 for handling. 50lbs doesn't seem like much difference, so should I change them out or will they be fine to go down the track with?
If you haven't tried this. Take some zip ties and tools to the track and remove your Front Swaybar links and zip tie the swaybar out of the way it will allow the front end of the car to rise more on hard acceleration. Just don't drive it like that on the street it will make the car handle like a pig. My .02 hope that helps.
