Body Roll?
Originally Posted by UAZ28SS
Umm... you can't really "hear" body roll. It's something you feel. Roll is when you send the car into a turn and the body leans to one side or another.
The wheels are trying to say turn right, but because of centripetal force and inertia the body wants to continue straight..the result is that the outside corner suspensions burdened with the weight of the body..lessening the cars ability to turn....under-steer
I really you like the body to stay over the wheels evenly over all four corners of teh car
Text book definition:
Definition: The leaning or tipping of a vehicle's body to one side when turning sharply. This reduces traction and increases tire scuff due to undesirable alignment changes. Body roll is controlled primarily by a sway bar, but the stiffness of the springs and shocks also play a role.
I have a good amount on my TA. I just ordered the UMI 3 point subframes and now I'm looking at what shocks/struts I want to go with. I hope that helps a good bit. Havent seen much gain from sturt tower braces but could those help with body roll.
Originally Posted by DuronClocker
Actually having a stiffer rear swaybar (less rear body roll) makes it easier to kick the rear end out (inducing a power slide).
people, you are forgetting an import part of the suspension and body roll.. bushings.. if have old warn out rubber bushing and your sway bars, control arms are trying to push on them.. its like jelly.. get some polyurethane bushings, one of the best things I have done, suspension wise.
Might be the cheapest place to start
LS1TECH Sponsor
Bushings don't alter roll stiffness..... If yours are junk, they will make your bars react more quickly (as they should), but don't ultimately make for less roll. Also, remember that all the bushings are about $80 or so when you get new endlinks (and that's a must because stock links snap all the time). New links and bushings come with new bar sets.
The way I see it, take your $80 and put them toward an appropriate set of bars. That $80 is a full 20% of the price of a front and rear set of my hollow bars. And there are less expensive bars as well (I sell a lot of bars, not just mine, not always the right answer for everyone). You get not only a lot better roll stiffness (33% in the rear, and 30%-45% stiffer than stock front bars depending on if you have the 30mm or an SS/WS6/1LE 32mm front bar).
__________________
