What is the best all around drag racing suspension???
im curious about this too...my friend MightyMouse just did Eibach Pro Kit with some CE shocks in the back im curious as to how thats gonna turn out....
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Would it help at all if I got some Relocation Brackets with my car the way it sits now or would it be better to go HAL's all around with regular springs in the back...??
What kind of springs are the best for drag racing in the rear?
I will need a softer setup in the future to get the times I want...
My current setup is the Bilstein Suspension from SLP...I ordered it with the car...rides great handles great, but hinders drag racing performance because of the lack of weight transfer...
I eventually will go HALS in the front, but whats the best to do with the back??
Probably V6 springs.
I don't think you'd have to worry about getting TOO MUCH weight transfer (like PSJ) because you won't be making as much power.
However, your car will squat like a ***** with HALs up front and V6s out back... <img src="graemlins/formula.gif" border="0" alt="[Pontiac]" />
!Dial-up Director
Stock shocks, prokit, and no relocation brackets are working for me! <img src="gr_images/icons/cool.gif" border="0">
![](http://www.bidsaloon.com/auction_images/Justin/silverta.gif)
LS1 Tech Administrator
BIGBOS,
The ultimate drag race suspension is pretty much what the Stock Eliminators are running. Hal Shocks and springs up front. Stock Torque arm. Pete Z bars (above the stock lower control arms). Hal Shocks in the rear. Stock Springs. Airbag under RR spring.
These guys pull 1.30 60' times on 9" radial slicks with out trans-brakes (for automatic cars). The stick cars run the same set-up. This is basically what Judson Massingill is running in his 3400 lb 9 second stick shift F-Body. He cuts 1.3X 60' times with 8000 rpm launches. If it works for him (and the stockers), it will work for you.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
For a little more $$$ than the HAL stuff, you can go with Afco shocks, which are double adjustable (rebound and compression) instead of the single adjustment on the HALS...
If I had known Afco made shocks for our cars sooner, I'd have spent the extra money over my HAL stuff (which I do like, though).
Just a thought.
Just a thought.
[quote]Originally posted by GeorgeC:
<strong>For a little more $$$ than the HAL stuff
Just a thought.</strong><hr></blockquote>
A little? They are double in price from what I've seen $373 per shock. You must have a connection <img src="gr_images/icons/wink.gif" border="0">
Yea, I will go with HALs all around and might put Eibach lowering springs in the rear of the car to make it a little more squishy the airbag is a good idea though... <img src="gr_stretch.gif" border="0">
BIGBOS,
You don't want the rear end to "squat", you want it to rise on launch. This rise will push the body up which in turn plants the rear axle harder to the track. Squat soaks up power and doesn't plant the axle to the surface. Be carefull taking advice from guys who aren't running 1.30 60' times or better when you are looking for the "best all around drag racing suspension". There's a world of difference in what's required to get 1.50 60' times and what's required to get them down to the 1.3s or better.
__________________
Yea Prostock had some squatting issues with his car..it actually did it too much...I think I'm gonna do HAL's all around eventually with stock springs in the back... <img src="gr_stretch.gif" border="0">
[quote]Originally posted by Patrick G:
<strong>BIGBOS,
These guys pull 1.30 60' times on 9" radial slicks with out trans-brakes (for automatic cars). The stick cars run the same set-up. This is basically what Judson Massingill is running in his 3400 lb 9 second stick shift F-Body. He cuts 1.3X 60' times with 8000 rpm launches. If it works for him (and the stockers), it will work for you.</strong><hr></blockquote>
What are Pete Z bars, (Are they similar to Upper control arms?) Thanks.
<strong>BIGBOS,
