Driveshaft Loop/Cross Brace
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
I put on headers and y-pipe recently....the stock flat brace that bolted on either side of the car under the pipe and shaft does not go back with the 3" pipe...what brace/loop are you guys using.?? thanks
Originally Posted by Luna
I have a BMR driveshaft safety loop, it has a large dip to accomodate larger pipe. BUT I have had problems with the flimsy stock torque arm rattling on it at higher speeds, maybe my torque arm bushings are just shot, but its something to watch out for. (BTW: I fixed it by shimming it with some washers and shoving a piece of heater hose between the torque arm and the loop)
i just got my tunnel mounted TA and it will go on tomorrow, the cat that i had spliced in is right in the tunnel so ill let you know about clearnace and how it all fits but that thing is a damn sturdy piece
Originally Posted by DONAIMIAN
The brace isnt on my car, and it hasnt been on for a while. I honestly cant remember it ever being on.
That piece of metal is so thin and so far away from the shaft that if something failed and the shaft hit it at speed its a good chance it would tear that piece in half. Ive been thinking about picking up a driveshaft loop latley and I would go with one that fit as close to the shaft as possible without having any rubbing issues.
I like the looks of the UMI tunnel-mounted TA setup with safety loop. I think fully optioned it is $400 plus shipping. That's what I plan on buying as soon as I pay off my credit card with the Koni SAs on it.
UMI has two versions depending on what kind of headers you have, which I thought was cool. Sounds like they are paying attention to other aftermarket pieces.
UMI is definately a customer's company as they watch the things that we do and build for those things, im planning on their k-member and a-arms as soon as i get money saved up, ive heard quite a few good things from them
