Hose mod (isolator) questions (no luck with search)
I did a search but didnt find exact answers... so here goes:
Im thinking of doing the hose-mod (on a LT1 TA), in my searching I found that some people say you need to have LCA relocation brackets and an adjustable PHB, I have neither... Should I stay away from doing the mod until I get these (if I do someday get them)? Ive tried to stay away from lowering my TA because it bottoms out in a few places already, but I believe it would look better if the rear wheel well gap was slightly smaller.
Thanks in advance,
Thanks in advance,
Originally Posted by DuronClocker
The front might look higher than the back on a stock car...that's all I could think of.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Yeah, I've noticed that on some of these cars too. I'd say go for it, that could be the only possible downside I see, and that's just a small appearance thing. I'm doing this and lowering the front that 3/4" or whatever it is when you do the lower perch mod on the Koni SA's that should be at my house waiting for me after work tonight
Yeah, I've noticed that on some of these cars too. I'd say go for it, that could be the only possible downside I see, and that's just a small appearance thing. I'm doing this and lowering the front that 3/4" or whatever it is when you do the lower perch mod on the Koni SA's that should be at my house waiting for me after work tonight ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
It will help functionally and asthetically to have the front dropped the same amount, which can be achieved by using Koni SAs on the lower perch.
You will most likely need an APHB (I did). Take your car in for an alignment and have them verify the rearend location before starting on the front end. I have never heard of having to use the LCA brackets, but as always, this may be a "YMMV" issue. I've got over 50k miles on this setup with no issues.
I've called Sam Strano on this issue and he didnt see any necessity to get an APRB or relo brackets with the hose mod. it wouldnt hurt, but the pinion angle is probably off by only a very small amount
