NEED HELP ABS INOP / BRAKE light on...
Guest
Posts: n/a
Need help I have a 98 Trans Am Ls1 and the brake light and the abs inop light or on, I have tried to clear the PCM and I even took it to the dealership, they checked the brakes and the computer but could not find anything, ecept that I needed to checnge the front brakes. Does anyone know how I can fix this? Someone told me about the peed sensor. Any help would be appreciated..thanks <img border="0" alt="[Pontiac]" title="" src="graemlins/formula.gif" />
Re: NEED HELP ABS INOP / BRAKE light on...
Check the rear housing, your rear ABS sensor setup might be unplugged or loose, it's the male/female connector.
I get that code because mine is unplugged since I have an ABS-less Moser 9".
