Will an M6 torque arm fit an A4 car?
If you look in my other thread about part #'s, you'll notice that there are 2 part #s for torque arms, A4 and M6 version. Will the M6 TA fit an A4? And vice versa?
The M6 torque arm is 52 cents cheaper than the A4 version, from gmpartsdirect. I wonder what the actual difference is. I assume they are interchangable, because all aftermarket torque arms are 'generic', in that they are not A4/M6 specific. I just wanted to be sure though, I've never seen a M6 torque arm.
Thanks
Dope
Thanks
Dope
Re: Will an M6 torque arm fit an A4 car?
Not sure if it will work but At the moment i have a auto rearend(don't ask) in my car and a MN6 torque arm... It does work fine as far as i know... Its a aftermarket one... but no problems at the moment... I don't think anyway... Hope this helps
Hmmm okay, so it'll bolt to the rear fine. I am assuming it attaches with the same mount and bushing at the front too, because I could only find one part # for a torque arm bushing (so I assume they are shared between M6 and A4 cars).
Hmm anyone got any pics of the M6 mount/bushing on the tailshaft of the transmission? Mine's out of the car right now so I can compare (mine was destroyed by a broken driveshaft).
Dope
Dope
no, the mount on the transmission is different
torque arm is the same though
<small>[ April 04, 2002, 09:35 PM: Message edited by: prockbp ]</small>
Hey prockbp, could you clarify that?
I realize the mount is different since they were 2 different transmissions, but maybe you are saying that the portion of the mount that the torque arm fits into is different too? If the arms are the same shouldn't they use the same bushing/mount style?
Alls I'm really asking is if a M6 torque arm will fit an A4's mount/bushing.
Thanks!
Dope
Thanks!
Dope
