Clicking Noise... Need HELP!!!
sounds like your kneuder valve is loose. might want to check that. <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
I am experiencing a clicking noise when I brake. It doesn't matter wether I'm moving forwards or backwards, although, it is more noticeable moving forward. When the weight shifts, there it is, *click*!, as if some thing isn't bolted down tight enough and there is too much play( <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> ). I've pulled the front tires off and inspected the calipers and discs, and am pretty confident its got nothing to do with the braking system.
The "noise" is deffinatly coming from the front of the car though. If any of you fine folks have ever experienced such a phenomenon, PLEASE!, help me out!
Thanks!
Brian <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Thanks!
