Wilwood Brakes and ABS? Need Help.
Has a anyone made the ABS system work with the Wilwood brake kit. I can't get mine to work and need the ABS.
I need help Big Time.
Jay
Jay
Jay
Did you install the system on the front or the back or both.
The front is a no brainer, since the abs sensor is part of the spindle assembly .
The rear is also a NB if you have 3ch ABS.
Biggest problem might be a loose or damaged connection going to a sensor.
