Subframes or Control Arms? Your opinion?
On a 01 TA WS6, stock suspension, which would you get and where exactly does each of these increase?
Im mostly street racing no X-cross. So launch traction is what is important here. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Thanks,
Brent
Al
IMO LCA's alone won't do much for you, but you can always add those later if you run into wheel hop problems.
<small>[ June 19, 2002, 08:23 PM: Message edited by: Fulton 1 ]</small>
<strong>who makes SFC's for convertibles?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">BMR does for sure and I think Kenny Brown does also, there's probably others out there also. All convert SFC are the weld on type, I'd like to see someone make a bolt-on SFC for them.
Al
<strong>who makes SFC's for convertibles?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">BMR does. I got some and helped alot.
And for me. The SFC's made the most difference.
<small>[ June 19, 2002, 08:46 PM: Message edited by: Ed LS1 Vert ]</small>
So, if you buy a new car every 2 years you don't need subframe connectors at all. There are other things to spend money on, like a torque arm, which is the best thing you can buy from my point of view. Or move the battery to the back, which is something you can't buy but have to do yourself.
For rear LCA's the 1LE arms are about $65 each and they have solid firm bushings that are just soft enough to provide some flex for the beam axle to twist on corners. This is something you could consider.
Poly LCA's in the rear are crap because of the beam axle design, so the poly LCA's beat up the attachment ears for the LCA's because something has to twist while the beam axle is high on one side and low on the other as the car corners. I am not going to capitalize each word in the preceeding sentence but this is how it works.
Spherical rod bearing rear LCA's are fine but a little "buzzy" for everyday use. You may be considering these.
I have Kenny Brown double diamond subframe connectors because they tie into the tabs for the rear LCA, which flexed a lot in my last F-body, even though I had subframe connectors to tie across the unibody section of the car. I think they weigh 38 pounds, which is really a lot compared to other types, but I plan to keep my car for 100,000 miles. It is a '98 1LE.
From '98 on convertibles have sub-frames from the factory.
As said before, get LCA's if you have wheel hop.
Fixed my problem, and I have 1LE.
<strong>We're missing something here.
Fixed my problem, and I have 1LE.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I was at Ralph's Hotrod Heaven saturday, under the car, and I asked Ralph what the heck people were talking about when they said convertibles came with SFC's from the factory. He pointed to some cheesy sheet metal pieces, saying, "Hardtops don't have this, and this..." I guess every little bit helps, but in this case, not enough. The Kenny Brown DD SFC's made for a huge improvement in the way my car handles.
