Wheel hop ?
Old Jun 20, 2002 | 02:31 AM
Judd's Avatar
Default Wheel hop ?
Hey folks, I've got Globle West Sperical LCA's, Eibach Pro-Kit Srings and Bilstien shocks. Rear tires are Yoko. 032Rs in 315/40/17 size. Problem is I'm getting some wheel hop, usually when slamming 2nd. Doesn't seem to it much when I first launch. Will the LCA relocation brackets get rid of it or will it take a new torque arm? Would a poly T.Arm bushing help? Don't really want to spend the bucks on a T.Arm right now but I have 4.10s in the stock rear and don't want to tear it up either. I know from my 4x4 experience that wheel hop tears up the rear, yea, yea, I know the 10 bolt is wimpy and is going to break anyway but I've got around 100 or so 1/4 passes on it with radials with 60fts in the 1.90 range and it ain't broke yet. Would like to help keep it that way. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> Thanks <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jun 20, 2002 | 02:56 AM
CRAGER's Avatar
Administrator
Default Re: Wheel hop ?
Do you have a panhard rod?
My SS came with the Bilstein suspension and I had massive wheel hop. After I had Hotchkis LCA's and panhard rod installed the wheel hop was gone, and I don't have the relocation brackets yet.
Peace,
Craig.
Old Jun 20, 2002 | 04:02 AM
Judd's Avatar
Yep,it's a adjustable one with rod ends.
Old Jun 20, 2002 | 05:07 PM
prockbp's Avatar
i'd say that control arm relocation brackets are your best bet....
Old Jun 20, 2002 | 08:11 PM
steve's Avatar
yes, the locaters should cure the wheel hop.
craig, is your car lowered?
steve frank
Old Jun 20, 2002 | 10:57 PM
CRAGER's Avatar
Administrator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by steve:
<strong>yes, the locaters should cure the wheel hop.
steve frank</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ya Steve, my SS came with the Bilstein suspension option from SLP. It's not "slammed" but I think it's about 1-1/2" drop.
I'm pretty sure I need the relocation brackets because my LCA's are at an angle when the should be level (from what I was told).
The relocation brackets and torque arm are on my to do list, but I'm in no hurry.
Peace,
Craig.
Old Jun 21, 2002 | 12:03 AM
RacerZ's Avatar
I have adj. pan hard bar, lower control arm , relocation brackets, Edelbrock torq arm & poly bushing and still have the same wheel hop. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> I guess I'll change the shocks next.
Old Jun 21, 2002 | 10:02 AM
prockbp's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by RacerZ:
<strong>I have adj. pan hard bar, lower control arm , relocation brackets, Edelbrock torq arm & poly bushing and still have the same wheel hop. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> I guess I'll change the shocks next.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">your problem could be caused by having polyurethane in all the wrong places...
Old Jun 27, 2002 | 11:10 AM
JIM's Avatar
JIM
Judd, I was wondering if you ever cured the wheel hop problem? I have a 2002 SS and I lowered it with the Eibach Pro-kit and it has real bad wheel hop. I was told the relocation brackets would work for the cure but just wondering if you fixed your problem and if you did what worked for you?
Old Jun 28, 2002 | 01:06 AM
Judd's Avatar
No,I haven't tried anything with it yet. Going to get a set of SFCs first. They won't cure the wheel hop but I just won't be 1/4 mileing for a while. To tell you the truth, my wheel hop isn't all that bad. Just a little worse than when it was stock but I do have the Globle West control arms. I don't get any when I launch, only when I ****** second. Would like to get rid of it completly though so I think a set of relocation brackets are next. Wish I could have been of more help.
Old Jun 28, 2002 | 11:46 AM
swtvictory's Avatar
I dont know why you would still have wheel hop but from my past experience with 2k C5 wheels, the bigger ones tend to hop.
My 18's hopped like a mother but my 16's never did once.
You really need to get rid of this wheel hop because it WILL destroy your rear quickly. How about going to a 16 inch tire? or buy 15 pro stars for the track? Other than that, if you have LCA's, relocation brackets, TA, panhard rod, I dont see why <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> , maybe you dont have the right settings on your LCA's, they are supposed to be parallel with the ground.
Try different techniques. Take care.
