SFC install (weld-on)
the bolt-on joint will slip and flex before the subframe connector will... that's not a good situation
If you want to use the weld-on type why would you want to use there tubular SFC, tubular SFC aren't as strong as there square ones also remember the SFC is only as strong as the weld.
Like I've always said it's your car and $$$ so do what you think is best.
<strong>the front uses two bolts to hold it to the body</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">that's exactly the problem.. the front subframe can easily twist on that joint... it's the most crutial point since that's where most the weight is
how do you know that tubular steel isn't as strong as the rectangular steel? polygons are not the strongest shape out there, triangles are stronger.. hyperboles are the strongest.. circles are shaped more like hyperboles
i have boxed SFC's.. they bend easily
<strong>I have always found it hard to convince guys that the bolt-on SFC are the way to go, but look at the Spectacle or SLP SFC. There double diamond, the rear uses the LCA bolt plus plus another bolt, the front uses two bolts to hold it to the body as well as two bolts more that hold it to the center of the car.
Like I've always said it's your car and $$$ so do what you think is best.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">But weld doesn't flex... and if it does it's most likely broke or braking....
In the end the cost is about the same or cheaper to get weld on vs bolt on (weld on are cheaper but you need to have someone weld)
That's great that there are four bolts but it still leaves room for flex...
how do you know that tubular steel isn't as strong as the rectangular steel? [/QB][/QUOTE]
It dosen't matter if you use the weld or bolt on kind there's going to be some flex, the part of the SFC that's welded to the body is quite a flimsy piece compared to the rest of the SFC.
If you look on BMR web site they even will tell you to use the boxed SFC if you're looking for strength, but hey maybe they don't know what there talking about.
<small>[ June 27, 2002, 01:49 PM: Message edited by: ss01gtw ]</small>
the weld on my SFC's makes a HUGE joint compared to the joint that two bolts make....
quote from the Global West website:
Using subframe connectors for high performance street and racing applications has been done for a long time. It is no secret that tying the car together with subframes not only stiffens the chassis but improves vehicle response. Global West has been building subframe connectors for 20 years. Over this period of time we have come to certain conclusions.
1. Subframes that attach to unibody chassis like the Camaro/ Firebird must be welded.
2. Subframes on unibody chassis must extend to the strongest point fore and aft for obtaining the best results.
3. Round tube subframes, yield stronger torsional resistance then square, per given weight..
4. Subframes should have large mounting areas to distribute the loads.
5. If you are serious about street performance,or you drive a convertible / T top, subframes are required.
http://www.globalwest.net/camaro93.htm
<small>[ June 27, 2002, 06:27 PM: Message edited by: prockbp ]</small>
My take is that BMR just says that so they can still sell the boxed ones, since the tubular one's haven't even been out for a year.
I place my jack under the door on the sub and lift both wheels NASCAR style.
Been doing it for 3 years now.
<strong>One of the subtle advantages of boxed over tubular is that the boxed can be used as a jacking point.
Been doing it for 3 years now.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Nope, no advantage there. I jack my car up by the Global West SFCs all the time.
Both wheels, huh? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
If I got boxed subframe connectors I would imagine I'd have to drive the car up on some wood planks to get it high enough off the ground that I could slide a jack under there. That would be just one more thing to bring to an autocross. Ugh.
<strong>I tried doing this on a friends tubular type and I was afraid that I was either gonna bend or collpse the tubing or the jack was gonna slip off.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have to agree with Weasel, the Global West tubular SFC's are the very stout, they are 2" diameter 1/8' thickness tubing. I jack my car up all the time by them lifting the whole side of the car.
I never worry about them slipping off, my floor jack fits nicely. Then again I NEVER get under a car supported only by a jack. Always use jackstands and / or ramps.
