Roll bar vs. SFCs
The car will by no means be set up oriented to drag-only. I know when it comes to drag/handling, you can't really have your cake and eat it too. I'm more or less looking for well handling car that will be "able" to drag. I know one of Sam's other customers cut 1.7x 60's on Koni SAs (which I now have), which is perfectly acceptable to me.
Suspension so far..
-poly-ended LCAs
-rod-ended aluminum PHB
-Koni SAs all around with lower perch and hose mods and stock springs
-24mm rear swaybar with poly links and mounts (will more than likely be changing to a 21mm this week)
I plan on changing the body-side bushings on the LCAs to rubber and replacing the PHB with a steel one with a poly/rubber bushing combination as well. Not a big fan of the extra noise I've gotten from the rear with the rod ends and poly stuff, and I don't really trust the stiffness of the aluminum bar. Aside from chassis stiffening, the next suspension piece I'm looking into is a UMI chassis mounted torque arm with driveshaft safety loop.
Is a 6pt roll bar going to give me the same kind of stiffness as having the 3pt SFCs? Is there going to be much benefit of installing the SFCs once I have the roll bar in?
I plan on getting a rollbar. I'm just curious as to whether a 6pt roll bar will make my car as stiff as having 3pt SFCs. I know full cages offer the most chassis rigidity obviously, but a 6pt is by no means a full cage either.
I'd like to avoid a full cage though because the halo will have to hang too low to clear my T-tops. As cool as I think that would look to see the cage bars across the t-top areas when they are out, it'd be almost impossible to deal with them there. As I said, assuming the rules haven't changed much since 02-03 for cages/bars, I should be good to 10.00, while adding better protection for road racing/street driving.
I would imagine that a rollbar would help torsional rigidity moreso than even a set of 3pt SFCs based on how they are tied together, but that's just my thinking. Only went through one semester of M.E. stuff, and I'd like to hear something out of experience as well.
And then if we're on this topic. Am I better off having the rear bars go to the wheel wells or the end of the rear framerails? I'd imagine the bars to above the fuel tank would be the worst, and the bars to the framerails would probably be the best, but at the same time, the bars will have to be longer to do that and I'd imagine they will lose some of their anti-torsional support the longer they are. Unless I were to do something like have the rear bars run back to the end of the frame rails and somewhere along that bar have each of those tie into the wheel well area as well.
EDIT: I care a lot about the torsional rigidity in the event that I get into more serious road racing events and such, not to mention the added safety.
-poly-ended LCAs
Bolt-in bars are a universal "one size fits most" contraption. Recommend staying away from them, unless you weld them in after installation.
A custom 4-point with fabbed and welded in 2-point SFCs may be a better way to go. If you really think you'll need the extra 2 attachment points in the rollbar (i.e., the down bars into the footwells) they can be attached to the same point as the front of the SFC, which will tie the rollbar and SFCs together at both ends of the SFC. This will increase chassis rigidity more so over the 3-point SFC alone, and allow for proper attachment of safety harness (which you'll need if you get into the 10's IIRC).
Main hoop should rise as high as possible to ensure adequate headroom clearance. Most bolt-in roll bars won't do that, and end up blocking some or most of rearward vision.
As an aside, my rod-ended PHB does make noise. It can be reduced by ziptying some heater hose around the metal collar bushing on either side of the rod end.
I like the idea of the 6-pt tying into the SFCs. I just wasn't sure if I would need SFCs as well. I'm going to need the two sidebars though to be legal at the track I'm pretty sure. I could be wrong though.
I just ordered my UMI tunnel-mounted torque arm today, so that will be going in when it gets here. As soon as I have that paid off, I will probably be ordering a rollbar from Wolf. Was looking at the Competition Engineering kit, but Young at BYUNSPEED told me to skip that and just go to a Wolf setup. I'll see what I can afford and work it out.
FYI, I was recommending custom 2-point SFCs that work in conjunction with the roll bar. The bolt-in SFCs may not be able to be welded to the roll bar in the right places (where the main hoop comes into the floor behind the driver/front passenger seat, for instance).
Picture it this way - the SFCs are like a piece of paper, and the rollbar welded to the SFCs are like a box. It is much easier to twist the piece of paper holding either end than the box.
If your rules allow it, the 3-point bolt-in/weld-in SFCs will help out. If they don't, get some 2-point SFCs that will work with your roll bar kit (tie into the main hoop and the down bars in the front). Also, look around for a chassis shop in your area. You might be able to get them to fab and install the bar and SFCs. May cost more, but safety shouldn't be scrimped on. JMHO.
I was thinking of building my own 4 pt rollbar but actually tie it into the car where the main hoop would not be seen, but the 2 bars to the rear would. The rear bars will also be tied into the cars unibody chassis at multiple points. With all the bars actually welded to the car all around it should give maximum rigidity (in at least the back half of the car anyway).
I don't have to be legal for any tracks, BTW.
