Loud high pitched squeak on left turns!!
car is a 96 v6 with z28 shocks, stock springs, 1le sways and lca's, aftermarket panhard, zexel torsen lsd, 4 wheel disks and 17 inch rims.
i have this extremely annoying problem where when turning left (and only left) at speed i get a very high pitched squeaking noise. i have to me making a fairly hard turn to hear it, and it wont do it when im going slow. i have replaced the front pads, but not the rear. like you say, its only at a certain point going around left turns, and i have to be going at speed. a cloverleaf style onramp (steady left turn) is a perfect example.
i have disks in back (self installed as opposed to stock drums) but the pads still have plenty of life. doesnt seem like it would be the differential. i was previously having problems with the diff, but i added some posi additive and that problem seemed to go away (i had a slight grinding noise coming from the diff... ironically on right turns!!). this seems like something different. id love to have it worked out.
