Hals with eibach pro kit on front, ok to run stock ws6 on rear?
hey i am getting this set of hals off of ebay with the eibach pro kit on front
http://cgi.ebay.com/ebaymotors/ws/e...item=1844627040
anyways the seller said the car was using the stock springs in the rear so i am asking will it be alright to use the ws6 springs in the rear of will it sit funny??
also if it is gonna look weird where can i just get the rear set?
thanks
thanks
The front Hals are adjustable so you can set your ride hight were ever you like. I have the Hals up front and I went with the adjustable Ground control system in the rear, this way you can set you ride hight front and rear were ever you like.
B <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Order them straight from Ground Control, I think it is Ground Control .com, if not just do a search you'll find it. The rear set up is about 200.00.
B
<small>[ August 05, 2002, 09:11 PM: Message edited by: BBWolf ]</small>
B
